TA 7299 P Toshiba IC Audio Amplifier datasheet needed
Aldo
Hi guys,
I 've been looking for this datasheet on the net, Toshiba site and many other sites, but I couldn't find it.
It is amazing, it is an "original" Toshiba IC, but nothing at all in their web site.
So if anyone of you guys have a link where to find it I will really appreciate your help !!
Thanks a lot
Al
PS . Very good job Mr. Electro Master, very useful info in your datasheet list !!!
I have the **broken link removed** -- unfortunately (for me at least) it is in Japanese. Of course, much of the pertinent data -- values, operating characteristics, etc. are annoted in standard format, making them usable.
To help out, here's some additional information...
  • the TA7299 and the TA7299P are the same device with reversed pinouts
  • The TA7299 is replaced by NTE1831 (reversed pin configuration)
  • The TA7299P is replaced by NTE1830 (normal pin configuration)
  • **broken link removed** from a Thai site (www.partsupply.in.th), which is a blatant ripoff of the **broken link removed**, shows the opposite cross-reference.
  • Comparing pin designations/voltages shown on the Japanese Toshiba datasheet to the NTE datasheet, based upon pins 4 & 7 being GND and pin 10 being VCC, my cross reference shown above is correct.
Hi ChrisP
Thank you very much for the information you provided.
I didn't know that NTE was the manufacturer of a direct
replacement, so if I need to replace it, I can use the 1830.
Thank you so much !!!!
Al
Here is the Datasheet
  • nte1830_1831_la7270.pdf
Data on line about the IC
