ARandomOWl
Hi everyone.
I am looking to interface a KType thermocouple to a PIC (specifically a 16F819) to display temperature on an LCD. (I already used the search function and found some thread, but not the info I was after). The temperature range that I am looking for is -200c to +50c. An accuracy of 1c is desired but not required. At first I planned to use the AD595 with an op-amp to provide a 0v to 5v input for the PIC's ADC, however I have just come across potentially another, better, solution.
**broken link removed** (Page 6) Shows "Offsetting and changing the gain". I would like to utilise this as it seems to void the need for an external op-amp. Now for some questions.
(AD595 datasheet)
(**broken link removed**)
I would like the output voltage from the AD595 to be 0v when the temperature on the KType is -200c. So I would need a voltage of -160uV on pin 8. Is that correct.
If so, how do I go about achieving a -160uV reference?
For a 20mV/c output am I correct in saying that I require the AD595 gain (GNew) to be 387.2? If so, I will proceed to calculate RExt using the formula in AN-274 (I don't yet have physical access to a chip to measure RFDBK but will do soon).
Will I need a dual rail supply for the AD595 in this configuration?
Lastly, is this a "good" way of doing things, or should I use an external op-amp as I previously planned to do?
Thanks in advance for any help or advice offered. Adrian.
(AD595 datasheet)
