Battery Monitor
This circuit flashes when the voltage drops to 4v. The voltage "set-point" can be adjusted by changing the 150k on the base of the first transistor.
Battery Monitor
Here's a simple circuit to monitor under voltage.
R3 sets the LED 'on' current.
Hi Mr Al,Hi,
Hi Mr Al,
I created a circuit just like yours about a year ago that didn't have the 1N4148 in series with the LED. I wondered why the diode was necessary. I looked at my notes and realized that the voltage on the cathode of the LM431 is real clear to 2.5 volts until the trigger voltage is reached, as a result the red,green and yellow LED's with a Vf near 2V will always be on without the diode. I found by using blue LED's the diode is not necessary as the Vf of the blue is over 3V.
Thanks for helping me remember the reason for the diode.
Ned
hi Al.
There is the TLV431 1.2Vref.
E.
At 12v and an LED with forward voltage of 2v nominal and nominal current of 20ma, a resistor of 500 ohms would be necessary, but i would drive it at less than 20ma so maybe 750 ohms or something like that as the life of the LED goes up sharply with lower than full rated current.
Yes a good idea with the blinking LED. An LED running at 10ma always draws 10ma from the supply (battery), but an LED at 10ma that blinks with a 50 percent duty cycle only draws 5ma average from the battery, and at 10 percent duty cycle it only draws 1ma average. I used this idea with a refrigerator monitor to reduce battery current draw and get the batteries to last for 2 years, so it make a BIG difference. They make blinking LEDs already but im not sure if you can get that low of a duty cycle from one of those.
Hi Roger,
Hey not a bad idea. That would accomplish both under voltage detection plus battery saving.
I'll take another look at this and get back here...
Hi Roger,
So you want to try the capacitors and resistors addition to get the LED to flash then?
What kind of flash rate are you thinking of here?
