I have a transducer driving circuit composed of a push-pull network of N & P channel FETs, driven by a microprocessor with a 40KHz TTL output through 6 inverters in parallel. The circuit was successfully switching 48 volts to the transducer until I wanted more voltage. I replaced the 48 volt source with an EMCO high voltage unit and biased it to about 140 volts. I upgraded my P & N channel FETs to a higher rating. Problem is now the FETs won't switch the new voltage source through. Does anyone know what the problem might be? Do I need to increase the power of the driving TTL signal? What minimum conditions need to be met for FET switching that maybe I am not meeting?
