polandrb
Hello from iraq
here is my problem i have 22 generators ranging from 30 KVA to 135 KVA. i am starting to experiance wet stacking(not enough load on generator) i need a 75% load to run with out damaging the engines. all are not acheiving 75% some are reaching 50% and others 35%. what i would like to do is build a load bank so i could bring the generators closer to 75%. and be able to test the generator set before i put them online for service. the other problem i have is there is no radio shack in iraq so all parts must be local purchased (real pain in the @#$) i can not find a diagram of a load bank or parts list. if you could piont me in the right direction. if i had pitchure of the parts needed it would help make purchase easier. generator info 100KVA = 50hz at 400volts,152 amps, 3phase, the 135 and 114 KVA = 400volts at 50hz, unsure of amps, also 3phase, any help would be great,
thanks to all you supporting us over hear.
