I have built this three times and it doesn't work? Is there something wrong with the design or am I an idiot? **broken link removed** **broken link removed**
It doesn't work in the simulator im using either.
From top to bottom in the schematic for R1 (multiturn pot) I have pin 3,2 then 1. (Is it possible that they're hooked up wrong? 3006p trimmers)
Im running it on 13.8V in a car and I tried with 7.5v and 15V in the house.
I got frustrated and decided to hook it up to a 15v supply and jump R3 with a clip-on soldering heat sink. 555's smell great when you fry'em. I have about 9 more tries before I run out of parts, but for now I will seek help in the forums and stick to the simulator. The IR array is rated at 920+nm but I bought them from china and they have plenty of visible light. I have been using a volt meter, and the array isn't getting enough voltage,(.5V out of the 2nd transistor) but just in case, I am using an IR sensitive camera as well. I am in a hurry and have to go to work now, but I will have more voltages later. I don't quite remember them all. I think that pin three on the 555 the voltage was okay, but after R3 It had only .5v and the transistors weren't doing much. Could it be that my 48LED arrays are too power hungry or something? I have looked up other examples of timing circuits with the 555 for the simulator I have (Yenka) and it seems that all of them have the controlling resistor where I have R2 and not R1, and what's with the funny loop on R1? I know that to get a reading on the resistance, It's the middle pin and one of the ends, but it seems to be completely bypassed when I have it all hooked up and there is no resistance between pin 3 and 1. BUT THE LIGHT SHOULD STILL COME ON RIGHT?? It only came on once on my first model, and stayed on. Maybe the timing was too slow but the potentiometer did nothing. Like I said, the simulator examples had the variable resistor in another spot. Thanks in advance for any advice. I am fairly new to this stuff.
Parts List:
ITEM .... Label on Schematic
PC Board
8-pin socket
Controller IC NE555 (8-pin)..................IC1
.47 uF Electrolytic Capacitor.................C1
.1uF or .01uF Ceramic Capacitor............C2
500K Multiturn Potentiometer................R1
(2) 100K Resistors....................... R2 & R4
1K Resistor .......................................R3
Kynar wire
2N2222 Transistor (Q1) (IR Driver) .......Q1
2N3055 Transistor (Q2) (IR Driver) .......Q2
Misc Mounting Hardware
High Power 48 LED array for 12v
Cigarette Lighter Adapter
Parts List:
PC Board
8-pin socket
Kynar wire
