If you mean to electrically connect the audio meant for a speaker into a microphone input jack, obtain a quality potentiometer of any value, 10K will work too; connect its extreme terminals as if it was a speaker and wire the center wiper terminal and ground to the microphone jack.
Adjust the speaker source for low volume and the potentiometer for a level comparable to as if it was a microphone with no distortion. That will be a position near the start of rotation.
I don’t really consider myself a musician. I would like to learn how to program computers. I know that USB headsets can communicate analog microphone and speaker signals to a computer. I would like to learn how to communicate analog signals to a USB headset that could pass this information on to a computer. I have input and output analog signals. I’m considering my analog outputs like speaker signals and my analog inputs like microphone signals. So, when I say that I would like to get microphone input from a speaker output, I really mean that I would like to connect analog output to analog USB headset input, and connect USB headset output to the analog input of another device. Though, I’m worried that the newer microphones and speakers will send and receive complicated signals and won’t be compatible with analog signals. I have thought of just placing the microphone of each device by the speaker of the other device, but I would prefer to make an electrical connection.
Hi Torben.
I do not understand why you say :
"Speaker output power can be many Watts. That energy has to go somewhere; a resistor burns it as heat. To bring the signal down to microphone levels a lot of Watts may need to be burned. "
Can you please explain ?Do you mean a speaker output connection with a 10K resistor instead of a speaker has to dissipate 'many Watts' somewhere ?
No, I imagine he was talking about using a potentiometer ONLY - where turning it almost entirely to the top could, potentially, damage both the pot and whatever you're feeding.
The correct way (assuming you wanted a pot?) it to use a high value resistor to feed the pot.
Very little power will be dissipated, as the resistor (and the pot) are high values.
Why not save yourself the headache (and the cost of a new headset) and just use a real sound card or audio interface...It would be helpful if you could state exactly what you are trying to do...
i didnt get this point.. could you explain more about the translator you are planning?I am trying to make an electronic translator for the LBC6K Laser Beam Audio Communicator found at **broken link removed** and a computer,
Can a sound card or audio interface accept signals with a voltage as high as that of the signals used to power speakers? Can a sound card or audio interface send signals having a voltage as low as signals produced by microphones?
I am trying to make an electronic translator for the LBC6K Laser Beam Audio Communicator found at **broken link removed** and a computer, but I’d even prefer to communicate the Laser Beam Audio Communicator with one of cypress’ PSoC boards, i.e. a microchip.
If you wish to, you can change the jumper block on H1 from pins 1 and 2 to
pins 2 and 3 and input a line level audio source on J1. Pin 1 of J1 (indicated
by the arrow) is where the audio should be connected and the ground for the
audio should be connected to pin 2 of J1. See the next page for a recap of
the jumper block positions.
- LBC6K manual, page 19
Could you give me some type of estimate of how much a resistor will distort the waveform of the audio signals? I’ve heard about attenuators, but I’m not sure what type would be the best for what I’m doing.
