StrikeR.DbZ
I recently bricked my laptop's bios and i have tried to recover it using floppy drive recovery method but it didn't work for me as its Boot Block is also corrupt. It is a phoenix Bios and i was thinking to reprogram its eeprom using an external eeprom programmer like from serial port or paralell port its number is mx 25L8005m2c SOIC but then i found out that my desktop also has the same kind of ic it is mx 25L4005apc P-DIP so i was thinking i could use a another same kind of EEPROM to try to reprogram that bios into a new blank eeprom by "hotswapping" technique then solder its legs to the laptop bios mount point by removing laptop bios chip and check if it boots up but the problem is that i have very little knowledge about eeproms so i need some help so if i could get some insight into eeproms and also need to know that can i substitute another ic, because where i live w25x80 and EN25t80 spi flash roms are available but would my desktop board support flashing a 8Mbit rom where as it has 4Mbit rom.
These are my doubts any help would be great.
Thanks in advance.
Thanks in advance.
