Mr RB
Hi guys, I've been playing with some PIC multi-thread concepts.
It is still in early stages but I have been trying to create some multi-thread systems in PIC firmware (in C language).
The goal of these systems is to act as a simple framework to create PIC projects using a multi-thread type methodology where the code tasks are defined as separate "threads" and as a whole the code will allow a level of multi-task "parallel" type performance;
# Will run many threads, each is independent
# Processor time can be divided between threads
# Threads are fast sequenced, and for many purposes "run at the same time"
# Threads can be easily added without affecting application performance
# Threads can be placed in any order
# Each thread can be executed (or not) with no effect on other threads
# RAM variables and special timers can be shared or dedicated to one thread
# Threads can be prioritised
# It may be a good general structure for many microcontroller projects
This work is still in a very early stage but I can see some possibilities. It seems to be a good framework for creating new projects from scratch that will need to have features added or changed later.
The web page is mainly descriptions of possible multi-thread systems and lots of source code examples, and there are 4 actual projects using the PIC-thread system including an LCD clock demo and two nice performance RS232 baudrate converters;
The PIC-thread web page can be seen here;
PIC-thread, simple PIC multi-thread systems
