Hello my friends,
I have just found a code about MPPT. I couldn't translate in Picbasic. I suppose an error in adjusting pwm duty (bold area). If you can translate the code i will be very happy. Thank you for now.
Best regards.
#include <16f876.h>
#DEVICE *=16 ICD=TRUE
#use Delay(Clock=20000000)
#use RS232(Baud=9600,Xmit=PIN_C6,Rcv=PIN_C7,brgh1ok)
float average_ad(byte chan) {
int i,avg_num = 32;
float avg = 0, temp_avg = 0;
set_adc_channel(chan);
delay_us(100);
for (i=1; i<=avg_num; ++i) {
avg += read_adc();
delay_us(100);
return(avg/avg_num);
void pwm1_duty100(long pwm_percent, long pwm_maximum) {
set_pwm1_duty((pwm_maximum/100)*pwm_percent);
main()
CONST float CHARGED = 14.4;
CONST long NDELTA = -1;
CONST byte AMP_CHAN = 0, BAMP_CHAN = 3, BVOLT_CHAN = 2, VOLT_CHAN = 1;
float current, voltage, watts = 0.0, old_watts = 0.0;
float batamps, batvolts, batwatts;
float temp_watts, watts100, amp100, volt100;
long delta = 1, pwm_max, pwm100;
long boost = 0, boost_counter;
byte led_count = 0;
output_low(PIN_C3);
setup_port_a(ALL_ANALOG);
setup_adc(adc_clock_div_32);
setup_timer_2(T2_DIV_BY_1, 49, 1);
setup_ccp1(CCP_PWM);
pwm_max = 200;
pwm100 = 85;
pwm1_duty100(pwm100, pwm_max);
output_high(PIN_C3);
output_high(PIN_C0);
delay_ms(1000);
while(TRUE) {
if (batvolts > CHARGED) {
delta = NDELTA;
output_high(PIN_C5);
else if (old_watts > watts) {
delta = -delta;
output_low(PIN_C5);
old_watts = watts;
pwm100 += delta;
if (pwm100 > 100) pwm100 = 100;
else if (pwm100 < 0) pwm100 = 0;
current = average_ad(AMP_CHAN)/40.885;
voltage = average_ad(VOLT_CHAN)/18.2887;
batamps = average_ad(BAMP_CHAN)/41.3428;
batvolts = average_ad(BVOLT_CHAN)/20.4831;
watts = current * voltage;
batwatts = batamps * batvolts;
output_bit(PIN_C0, (++led_count & 0x01));
delay_ms(500);
Best regards.
#include <16f876.h>
int i,avg_num = 32;
delay_us(100);
avg += read_adc();
delay_us(100);
main()
byte led_count = 0;
output_low(PIN_C3);
pwm_max = 200;
pwm100 = 85;
delay_ms(1000);
while(TRUE) {
delta = NDELTA;
delta = -delta;
output_low(PIN_C5);
old_watts = watts;
pwm100 += delta;
delay_ms(500);
