roadmanjim
I’m trying to repair a Litebook (older model). This is a hand-held, battery-powered device with approximately 24 LED’s to mimic sunlight. It is intended to help with modifying disrupted sleep patterns and reduce the down side of Seasonal Affective Disorder (SAD). Unfortunately, the machine is reporting that the battery needs to be charged even after sitting all night. I assumed that the battery was dead due to the age of the machine since it would not hold a charge and the indicator LED blinked without end (from the user's manual).
I bought a new battery, removed the wiring assembly from the original and get the same result. The battery is a TR18650 3.7v 2400mAh Lithium Ion battery (same specs as original). The original battery’s wiring assembly appears to be the “charging computer” which consists of two piece of flat metal running from negative to the positive anode (cathode?) end. On the positive end, there is a small circuit board numbered H3588C with three wires running to a small connector for the “mother board” of the device. The original wiring assembly was shrink-wrapped to the old battery the new is not.
Is it possible that the charging computer is fried? If so, is it safe to assume that they are all wired the same? I did see one version of the batter with the same part number that was being sold with the charging circuit/computer attached. I passed since the wires were different colors and wired to the connector in a different order.
Any and all ideas would be greatly appreciated.
