jawnn
I am a year round bicycle commuter, and need to heat my mittens with batterys.
I need a pulse width modulator that I can build for 3.7 or 3.2 volt batterys. The wire that I have in my gloves is about 15 ohms.
I found a circuit on robotroom.com that uses only one inverter chip, two diodes, two capacitors and a variable resister. It runs on 2 to 5 or 6 volts, and it puts out only 25mA, so I think I need to drive a transistor and a resistor; But do not know how to figure that one out.
I can give you a link to the schematic if it is not forbidden here.
Maybe there is a schematic for a simpler pwm using a 555 timer?
I may have to build a charger for the batteries also because it is very difficult to find one that will charge from a 12-15 volt source.
I also need a source of resistance heater wire.
