blueroomelectronics said:A heat shrink type blowdryer will soften it up, then just peel away.
Andy1845c said:Has anyone ever had any luck de-potting a circuit? I bought 5 strobe light power supplys in need of repair off ebay. Of the 5, the three that were not pictured are fricken potted!
Will it re-melt at a temp that won't melt the rest of the circuit?
mvs sarma said:soaking the item in Di Methile Chloride (forbid spell mistakes-(not a chemistry person) the potting compound will slowly soften. at room temp he says, it took a week. at say 80 deg celcious
Thanks John for the moderation and updation.jpanhalt said:In the USA, it's known as dichloromethane, methylene chloride (not methyl choride), and methylene dichloride. It boils at about 40 C or so. I would not suggest trying to heat it to 80 degrees C. Most important, it is one of the active ingredients in solvent-based paint strippers, which are still available in the US (maybe not in California). Major toxic effects are neurological, hepatic, and of course, cancer.
One advantage of using a paint stripper is that they also contain methanol, which stabilizes the methylene chloride. Pure methylene chloride can also decompose to phosgene, which was used as a chemical weapon in WW I. John
Andy1845c said:The thing I worry about with soaking these with anything is the they are 12v strobe light supplys and have several transformers on the board. Couldn't soaking them in chemicals dissolve the insulation on the windings?
Andy1845c said:Hmm, well, if I get some time tomarrow I might try the heat and see what that does. If that dosn't work I will look into the solvent. I don't really have anything to lose I guess.
yes, I understand your anxiety and need or urge to reach the circuit. i had this situation earlier. if the resistors and other things , can ofcourse be replaced, as long as the legend is ok. shorted diodes like, and if legend is also gone - reverse engg would be taxing the mind.Andy1845c said:Well, I tried about 45 minutes at 250 degrees. It dosn't soften at all, but rather gets kind of brittle. You can then scrape it off with a knife. Wouldn't be so bad if these things wern't so darn big. Problem is I can't see whats under the potting, so I end up stabbing components and getting the kinfe point caught under 1/4 watt resistors and the like. I would certinly do far more damage then good removing it this way.
I do have some paint stripper around. Not sure whats in it though. I guess I could try that. Like I say, nothing really to loose.
Andy1845c said:Well, I tried the paint stripper I have, and it didn't do anything after several hours of soaking. It says it contains methylene choride: 79-09-2 I don't know what the numbers mean though?
Can you get just methylene choride? Or is paint stripper the closest I will come with out being a chemist?
