I'm trying to interpret a circuit diagram at http://www.z80.info/z80test0.htm in particular this one: http://www.z80.info/gfx/z80test0.gif
Purpose:
My goal is to one day build a very basic Z80 computer with keyboard input and serial output that I can view on a terminal emulator (or a real terminal, if I had one). The purpose of this is for its amusement (or frustration?) and as a learning experience. The software side should be the easy part for me, the hardware is what I will probably learn the most from as my electronics knowledge is pretty rudimentary. To start with I want to build the most basic test circuit I can find.
Question:
First question: What is "470 E"? Is this some other notation for ohm? Is it 470 ohm?
Second question: Why doesn't the picture match the circuit diagram? Is this some circuit diagram convention I'm not aware of? I mean, GND and VCC are perpendicular to the rest of the pins in the circuit diagrams, whereas the real Z80 is a DIP with no pins at all in these locations. I find that this makes the circuit diagram harder to read. I have to map between the real physical pins and the pins in the diagram.
Purpose:
Question:
