Resource icon
Alcohol detector and engine cut off. 2013-06-29
in order to start the car you have to blow to the sensor having a flowsensor (can be madeform a heated filament when blown the resistance drops and this can be detected. but for test we use condensor MIC) . its also coupled with a alcohol sensor. it is passed through a combinational logic and then a decision is taken whether to turn on / off the engine.
>>the sensor is attached with the lm3914
>>the output is attached to 74147
>>the outputs will get high in bargraph mode
>>it is decoded by 74147
>>its given to 7447 ( 7 segment decoder)
>>the alcohol level is displayed to 7 segment.
>>the lm 741 is used as a flow detector (in place of switch use a condenser MIC)
>>the maximum alcohol level is detected by 3914 and its use to trigger a latch
>>the output is anded with the input from flow sensor.
>> then its passed to a transistor logic for turning on the path to the engine.
Proteus file:
View attachment asdasd.zip
  • asdasd.zip
Author
magvitron
Views
8,967
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from magvitron
Latest reviews
Great Circuit. These should be in every car!
