Resource icon
Digital Stop Watch 2011-06-18
A digital stop watch built around timer IC LM555 and 4-digit counter IC MM74C926 with multiplexed 7-segment LED display. The MM74C926 consists of a 4-digit counter, an internal output latch, npn output sourcing drivers for common cathode, 7-segment display and an internal multiplexing circuitry with four multiplexing outputs. The counter advances on negative edge of the clock. The clock is generated by timer IC LM555.The circuit works off a 5V power supply. It can be easily assembled on a general-purpose PCB. Enclose the circuit in a metal boxvwith provisions for four 7-segment displays, rotary switch S1, start/stop switch S2 and reset switch S3
Schematic
Notes
  • To reset the circuit press S3 so that the display shows ‘0000.’
  • To start open switch S2 for the stop watch to start counting the time. If you want to stop the clock, close S2.
  • Rotary switch S1 is used to select the different time periods at the output of the astable multivibrator (IC1).
Author
3lectrix
Views
8,537
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from 3lectrix
