Resource icon
Electronic Combination Lock 2011-03-10
This circuit is very basic to build. To open a the lock which is connected to the K1 Load you must press each momentary switch in the correct sequence. The sequence used in this circuit is S1,S2,S3,S4. If any of the other switchs are pressed the circuit will reset and you will need to start over. Depending on how you wire the switchs, you can use any 4 switch combination.
Author
ElectroMaster
Views
1,280
First release
Last update
Rating
4.00 star(s) 1 ratings
More resources from ElectroMaster
