Resource icon
Keypad-Based Vehicle Engine Immobilizer 2015-04-19
Features …
    • Low cost, easy-to-build compact design
    • 2-points of circuit immobilization …
    • Concealable main circuitry, keypad & relays fully isolated
    • 10,000 possible 4-digit codes …
    • Code set / quickly changeable via keypad buttons
    • Flashing LED when armed …
a-jpg.92102
b-jpg.92103
:: Electrical Schematic ::
c-jpg.92104
:: MikroC Source Code ::
* PROJECT:
      DIY Keypad-based car engine security system ...
      Copyright ©2010 Trent Jackson all rights reserved
* MCU:
      PIC16F628a @4MHz
// :: Global scope variables :: //
unsigned short scan = 0;
unsigned short userCode[6];
unsigned short user[6];
unsigned short keyDown = 0;
unsigned short active = 1;
unsigned short tmrLED = 0;
unsigned short progMode = 0;
unsigned short codeCorrect = 0;
unsigned short hashPressed = 0;
unsigned short ukeyPointer = 0;
unsigned short Pinattempts = 0;
unsigned short i = 0;
unsigned short j = 0;
unsigned int timeout = 0;
unsigned int tmrIgnit = 0;
// :: Defines :: //
// Keypad rows ...
#define rowA PORTB.F0
#define rowB PORTB.F1
#define rowC PORTB.F2
#define rowD PORTB.F3
// Keypad columns
#define colA PORTB.F4
#define colB PORTB.F5
#define colC PORTB.F6
// LEDs ...
#define LEDa PORTA.F3
#define LEDb PORTB.F7
// Relays
#define relayA PORTA.F0
#define relayB PORTA.F1
// Ignition
#define ignit PORTA.F4
void interrupt()
  tmrLED++;
  tmrIgnit++;
  TMR0   = 96;
  INTCON = 0x20;
void flashLEDa()
   LEDa = ~LEDa;
void flashLEDb()
   LEDb = ~LEDb;
void playValidSND()
   for (i = 0; i < 5; i++)
      Sound_Play(2000, 25);
      Delay_ms(100);
void playErrorSND()
      Sound_Play(250, 50);
      Delay_ms(100);
void rstUser()
   ukeyPointer = 0;
   codeCorrect = 0;
   hashPressed = 0;
      user[i] = 255;
unsigned short getKey()
                      :: Multiplex 4x3 keypad function ::
   1. Cycle through rows and check for corresponding column being set ...
   2. Return the key if col is set (active high)
   3. Protocol implementation(s) / limitation(s):
                                    a. No simultaneous key sequences
                                    b. Key detect on release ...
                                    c. Very responsive with zero bounce
      switch (scan)
         case 0: // :: First col (1, 4, 7, *) :: //
            // Set cols
            colA = 1;
            colB = 0;
            colC = 0;
            // 5mS delay allow port to settle
            Delay_ms(5);
            // Check for button press ...
            if (rowA == 1)
               return  1;
            else if (rowB == 1)
               return  4;
            else if (rowC == 1)
               return  7;
            else if (rowD == 1)
               return  54;
            break;
         case 1:
            // Set cols
            colA = 0;
            colB = 1;
            colC = 0;
            Delay_ms(5);
            if (rowA == 1)
               return  2;
            else if (rowB == 1)
               return  5;
            else if (rowC == 1)
               return  8;
            else if (rowD == 1)
               return  0;
            break;
         case 2:
            // Set cols
            colA = 0;
            colB = 0;
            colC = 1;
            Delay_ms(5);
            if (rowA == 1)
               return  3;
            else if (rowB == 1)
               return  6;
            else if (rowC == 1)
               return  9;
            else if (rowD == 1)
               return  55;
            break;
   // Inc to next col ...
   scan ++;
   // Reset after last row
   if (scan == 3)
      scan = 0;
   // Nothing pressed, 255 denotes this
   return 255;
void main()
  CMCON = 7;          // Disable analog comparators
  OPTION_REG = 0x84;  // Assign prescaler to TMR0
  TMR0  = 96;         // Timer0 initial value
  INTCON = 0xA0;      // Enable TMRO interrupt
  TRISA = 0x10;       // PortA as output ...
  PORTA = 0x00;       // Init port, all pins low
  TRISB = 0x0F;       // 4 inputs & 4 outputs
  // Using snd lib for short beep on key press
  Sound_Init(&PORTA, 2);
  // Leds both off
  LEDa = 0;
  LEDb = 0;
  // Relays off
  relayA = 0;
  relayB = 0;
  // Cols off ...
  colA = 0;
  colB = 0;
  colC = 0;
  // Null user vars
  rstUser();
  // Fetch 4-digit code from EEPROM
  for (i = 0; i < 4; i++)
     Delay_ms(50);
     userCode[i] = EEPROM_Read(i);
  // Load default code
  if(userCode[0] == 0xFF)
     userCode[0] = 1;
     userCode[1] = 2;
     userCode[2] = 4;
     userCode[3] = 8;
  // :: Infinite program loop :: //
  while(1)
      // :: Armed flash red deterrent led @~2Hz :: //
      if (pinAttempts < 3)
         if (active == 1)
            if (tmrLED >= 100)
               flashLEDa();
               tmrLED = 0;
         else // Not armed
            if (progMode == 1)
               if (tmrLED >= 100)
                  flashLEDb();
                  tmrLED = 0;
            else if (ignit == 1)
               LEDb = 1;
               relayA = 1;
               relayB = 1;
               tmrIgnit = 0;
            else // Grn led + rlys off when no ignition
               if (tmrIgnit == 1000)
                  LEDb = 0;
                  relayA = 0;
                  relayB = 0;
                  tmrIgnit = 0;
         // :: Fetch keys :: //
         if (keyDown != 1)
            user[ukeyPointer] = getKey();
            if(user[ukeyPointer] != 255)
               // Flag set ...
               keyDown = 1;
               // Play tone
               Sound_Play(888, 25);
               // 50mS debounce
               Delay_ms(50);
               // Inc pos in array
               ukeyPointer++;
               // Reset after 5 keys
               if (ukeyPointer == 5)
                  ukeyPointer = 0;
         else // Wait for key release
            if (rowA == 0)
               if (rowB == 0)
                  if (rowC == 0)
                     if (rowD == 0)
                        // Flag off ...
                        keyDown = 0;
         // :: See if user has entered in the right pin :: //
         if(user[0] == userCode[0])
            if(user[1] == userCode[1])
               if(user[2] == userCode[2])
                  if(user[3] == userCode[3])
                     codeCorrect = 1;
                     pinAttempts = 0;
         // :: Detect if hash key has been pressed :: //
            if (user[i] == 55)
               hashPressed = 1;
               break;
         // :: Hash to arm / disarm system :: //
         if (progMode == 0)
            if (hashPressed == 1)
               if (active == 1)
                  if (codeCorrect == 1)
                     LEDa = 0;
                     active = 0;
                     playValidSND();
                  else
                     playErrorSND();
                     pinAttempts ++;
               else // ARM if vehicle ignition is off
                  if (ignit != 1)
                     LEDb = 0;
                     active = 1;
                     relayA = 0;
                     relayB = 0;
               rstUser();
            // :: Star key after entering in pin to set new pin :: //
            else if (user[4] == 54)
                  if (active == 0)
                     if (ignit == 1)
                        progMode = 1;
               else
                  pinAttempts ++;
               rstUser();
         else  // :: User is programming in an new pin code :: //
            if (ukeyPointer == 4)
               // Save code to eeprom ...
                  userCode[i] = user[i];
                  EEPROM_Write(i, userCode[i]);
                  Delay_ms(20);
               // Reset & bail
               progMode = 0;
               rstUser();
      else // 3 incorrect pin attempts in a row (lock out system for a few mins)
         if (timeout == 0)
            LEDa = 0;
            LEDb = 0;
         if (timeout < 50)
            playErrorSND();
            flashLEDa();
            flashLEDb();
            timeout ++;
         else
            timeout = 0;
            pinAttempts = 0;
            LEDa = 0;
            LEDb = 0;
  • Like
Reactions: faysalcng
Author
MCU88
Views
12,196
First release
Last update
Ratings
0.00 star(s) 0 ratings
More resources from MCU88
