Resource icon
PIC Single-Chip 4-Digit 24-Hour Clock 2014-05-21
I'd like to share a relatively simple single chip 4-digit LED Clock project that uses a PIC16F1828 microcontroller, a 32768 Hz crystal time base, a four digit LED display, and just a handful of other parts. This low parts count design is due in part to experiments with some very bright miniature multiplexed 4-digit displays which are available from Sparkfun in red, green, yellow, white (all $1.95), and blue ($2.50) colors.
4-digit-1-png.86240
Hardware
The circuit was built on a Radio Shack prototype board (sku 276-149) with a plastic laminated paper silk-screen glued onto the component side of the board. I used 30 guage Kynar wire and point-to-point wiring on the copper side of the board. The picture above was taken before I added the 32768 Hz crystal and associated capacitors.
The circuit does not include column/digit driver transistors and relies on the combined ~250 ohm RDS(ON) resistance of the PIC I/O pin high side and low side FET drivers for segment current limiting. The display is refreshed one segment at a time (1/32nd duty cycle) to provide even brightness across the entire display.
4-digit-schematic-jpg.86241
Parts List
1 ea. PIC16F1828-I/P (DIP package)
1 ea. 0.1-uf (100nf) ceramic capacitor
2 ea. 22-pf ceramic capacitors
1 ea. 32768 Hz (12pf) watch crystal
1 ea. 10 kOhm, 1/8th watt carbon film resistor
4 ea. 1N914 or 1N4148 silicon switching diode
1 ea. Sparkfun COM-09483 Red Common Anode 4-Digit Display
4 ea. generic momentary contact switch
1 ea. Soberton GT111P Piezo Speaker
Misc. sockets, connectors, prototype circuit board
Software
The HEX file in the ZIP file attachment can be used directly with a PICKIT2, PICKIT3, or similar device programmer to program the PIC16F1828. The program source file is also included in the ZIP file attachment. The program was written using the free/lite version of BoostC from Sourceboost and it uses 339 of the 4096 words of program memory available in the 16F1828.
The program configures the 16F1828 to run from the internal oscillator at 8-MHz and the Timer 2 module is configured to generate 250-usec (500 cycle) periodic interrupts. The Timer 1 low power oscillator is enabled for the 32768 Hz crystal. The ISR (interrupt service routine) is responsible for refreshing one new segment of the display each interrupt (1/32nd duty cycle) and it also polls Timer 1 for one second time-base intervals to update the RTC (real time clock) variables. All thirty two segments of the display are updated once every 8-msecs for a 125-Hz refresh rate.
Operation
The <SET> switch is used to toggle between "set" and "run" modes. Press <SET> to enter "set" mode and the "hours" display group will flash at a 2-Hz rate. While in "set" mode the <Rt> arrow key is used to toggle between the "hours" and the "minutes" display groups and the <Up> and <Dn> arrow switches are used to increment (+) or decrement (-) the value of the current flashing display group. The "hours" display group will rollover from 23 to 0 (+) or 0 to 23 (-) and the "minutes" display group will rollover from 59 to 0 (+) or from 0 to 59 (-). The <Up> and <Dn> arrow switches will repeat when held down. Press <SET> again to exit "set" mode and enter "run" mode (display stops flashing). While in "run" mode, the <Up> arrow, the <Dn> arrow, and the <Rt> arrow switches are disabled. Those switches are still sampled and debounced in the interrupt service routine and you'll still hear a "new press" beep when you press one of them, but they're ignored and cleared by the logic in the program.
Have fun. Cheerful regards, Mike
  • 16F1828 Clock v1.zip
  • Like
Reactions: Dann23
Author
Mike - K8LH
Views
8,439
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Mike - K8LH
