Resource icon
TV Remove Blocker 2011-12-18
Just point this small device at the TV and the remote gets jammed.
Theory of Operation
The 555 IC (see our 555 Timer guide) is wired as an astable multivibrator for a frequency of nearly 38 kHz. This is the frequency at which most of the modern TVs receive the IR beam. The transistor acts as a current source supplying roughly 25mA to the infra red LEDs. To increase the range of the circuit simply decrease the value of the 180 ohm resistor to not less than 100 ohm.
It is required to adjust the 10K potentiometer while pointing the device at your TV to block the IR rays from the remote. This can be done by trial and error until the remote no longer responds.
Schematic
Author
ElectroMaster
Views
8,652
First release
Last update
Rating
4.00 star(s) 1 ratings
More resources from ElectroMaster
