Resource icon
Two Different Full-wave Rectified Voltages From Center-tapped Transformer and Bridge Rectifier 2016-08-01
The schematic below shows a simple way to get two full-wave rectified voltages from one center-tapped transformer winding and one bridge rectifier.
Adding a capacitor filter at the center-tap gives roughly half the DC voltage from the center-tap output to ground as compared to the bridge output to ground.
This can be useful for example, if you want to build a power supply with two different output voltages, such as 5v, along with a higher voltage, such as 10-12V. (The LTspice simulation is shown for a 12Vrms center-tapped transformer).
This minimizes dissipation in the linear regulators and reduces the transformer current requirements.
This works because all 4 diodes are acting as a full-wave bridge for the outer transformer connections while the center-tap is using the two bridge diodes to common as a full-wave rectifier.
The two bridge rectifiers connected to common are, in effect, doing double duty.
It may look a little confusing since normally a full-wave rectifier is shown with the diodes in the outer windings to the output with the transformer center-tap grounded, but it works just as well with the diodes in the outer windings as the ground path and the output taken from the center-tap.
Of course it should be apparent that the transformer and bridge rectifier must be rated for the sum of the currents from the two outputs.
Typically the transformer should be rated at least 2 times the bridge DC current plus 1.4 times the center-tap DC current.
This is due to the high RMS value of the current pulses charging the output capacitors (true of all rectifier-capacitor supplies).
Note the increased current in the ground diodes of the bridge (ID4 shown) due to it having to carry the sum of the two output currents.
  • Like
Reactions: atferrari
Author
crutschow
Views
7,257
First release
Last update
Ratings
0.00 star(s) 0 ratings
More resources from crutschow
