Resource icon
Water Level Alarm 2011-12-29
This circuit will produce an audible alarm when the water level reaches a preset level.The circuit can be powered of a 3V battery and is very handy to use.
The circuit is based on an astable multivibrator wired around IC1 (NE 555).The operating frequency of the astable multivibrator here will depend on capacitor C1, resistances R1,R2 and the resistance across the probes A&B.When there is no water up to the probes,they will be open and so the multivibrator will not produce oscillations and the buzzer will not beep.When there is water up to the level of probes,some current will pass through the water,the circuit will be closed to some extend,and the IC will start producing oscillations in a frequency proportional to the value of C1,R1,R2 and the resistance of water across the probes.The buzzer will beep to indicate the presence of water up to the level of the sensing probes.
Schematic
Notes
  • The circuit can be powered of a 3V battery.
  • Assemble the circuit on a good quality PCB or common board.
  • The probes can be made of two insulated copper Aluminiun wires.
  • Place the probes at the position where you have to sense the level.
Author
3lectrix
Views
2,134
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from 3lectrix
