8x8 matrix
    Blog entry posted in 'Projects', October 18, 2015.
    another display i made recently, 8x8 matrix, controlled by 74595 shift registers & couple darlignton arrays.
    takes only 3 pins from micro and can control god knows how many pins
    94783
    only scrolling needed now!
    cePYww2SSa0
    int dataPin = 2;        //IC 14       //Define which pins will be used for the Shift Register control
    int latchPin = 3; //IC 12
    int clockPin = 4; //IC 11
    //OE-GND
    //MR-VCC
    int const t = 2000;
    int count;
    int x =
    B10000001,
    B01000010,
    B00100100,
    B00011000,
    B00011000,
    B00100100,
    B01000010,
    B10000001,
    byte x2 =
    B01111110,
    B10111101,
    B11011011,
    B11100111,
    B11100111,
    B11011011,
    B10111101,
    B01111110,
    byte columns =
    B00000001,
    B00000010,
    B00000100,
    B00001000,
    B00010000,
    B00100000,
    B01000000,
    B10000000,
    void setup()
    DDRD = DDRD | B00011100;
    void loop()
    for ( int8_t a = 0 ; a < 8 ; a++ )
    PORTD = B00000000;
    shiftOut(dataPin, clockPin, MSBFIRST, columns); //Send the data #2
    if (millis() / 1000 % 2)
    shiftOut(dataPin, clockPin, LSBFIRST, x); //Send the data #1
    else
    shiftOut(dataPin, clockPin, LSBFIRST, x2); //Send the data #1
    PORTD = B00001000;
    delayMicroseconds(t);
    Comments
    koolguy, October 31, 2015
    takes only 3 pins from micro and can control god knows how many pins which pins are those of 595
    i have seen that in circuit anyway, but i have not understand the 2 clock signal.
    fezder, October 31, 2015
    The '595 uses these pins: data(14), latch(12) and clock(11), numbers correspond to ic pin numbers. The data is sent via 8-bit serial, how many times this 8-bits are sent depends how many 595's you have connected in series, for each you need to send one more, and the first 8bits you send is retrieved at last 595, so if you send B10001000 and B11111100, that B10001000 is seen at last one of 595's, this case there are two of 595. Also what matters is whether you use MSB or LSB for sending bits.
    So the basic pattern is: latch low->data in->latch high
    manoj soorya, December 15, 2015
    where we can use this circuit?
    fezder, December 15, 2015
    well this 8x8 circuit is small but easily expanded to like scrolling display or wherever you need matrix display. I now have octal transistor arrays which play better along with 8-bit stuff like 74595, just a mention. Feel free to use this circuit & code, manipulate it for your needs
EE World Online Articles
Loading
