IR Beam Break Test Bed
    Blog entry posted in 'Electronics and Other Ramblings...', December 03, 2010.
    So we presented a simple IR receiver/emitter pair here. What can we do with this? How about an example of a test bed where we can determine whether an IR beam is broken.
    To do this two microcontrollers are used to control the IR emitter and IR receiver independently. Operation is obtained by sending a known RS232 communication (single character - "beam" character) through the IR link. The known RS232 character is sent three times within 100msec. If the receiver fails to receive any transmission within 100msec, the IR link (beam) is considered broken and an LED indicator reports this condition. This may be a bit of an overkill for a basic beam break circuitry, but it provides very good results.
    The original beam break circuitry was built using a single microcontroller as shown below.
    But using separate microcontrollers for the emitter and receiver allows to use any type of separation between the two. The following pictures shows the connections between the microcontrollers and the IR emitter and receiver.
    Code Description – Beam Break Test Bed:
    The code for this basic beam break test bed was created using Oshonsoft Basic. This language is not as complete or provides as much functionality as others (e.g. CCS C), but it can be readily obtained and used.
    The emitter code can be summarized as follows:
    • On power-up setup MCU for 40kHz PWM output on RB0,
    • setup the SW UART for transmission at 1200bps on RB5,
    • send RS232 “beam” character approximately every 33msec.
    The receiver code can be summarized as follows:
    • On power-up setup TMR1 for 100msec,
    • setup the HW UART for reception at 1200bps on RB2,
    • monitor HW UART for reception of RS232 character,
    • monitor RS232 for “beam” character,
    • sample every 100msec for RS232 “beam” character,
    • if “beam” character was received within the 100msec, turn off LED (or keep off, if previously off),
    • “beam” character was not received within the 100msec, turn on LED (or keep on, if previously on).
    Code - Emitter:
    '* PIC16F88 * IR Transmitter Test Bed *'
    'Title: IR Transmitter
    'Description: This program uses MCU to send an IR transmission.
    '>>>>>>>>>>>>>IR transmission is sent by "ANDing" an RS232 character and a 40kHz PWM.
    '>>>>>>>>>>>>>Transmission sent three times about every 100msec using the SW UART.
    'Author: languer (2010)
    'Pin Allocation:
    'PIN# Main_Fn
    'RA0 -> not used
    'RA1 -> not used
    'RA2 -> not used
    'RA3 -> not used
    'RA4 -> not used
    'RA5 -> not used
    'RA6 -> not used
    'RA7 -> not used
    'RB0 -> PWM Output
    'RB1 -> not used
    'RB2 -> not used
    'RB3 -> not used
    'RB4 -> not used
    'RB5 -> RS232 IR output (SW_UART-RX)
    'RB6 -> PGC - Programming clock
    'RB7 -> PGD - Programming data
    'Usage Information:
    'Uses internal clock @ 8MHz
    'IR Baud rate (SW UART): 600bps - 2400bps
    'General Configuration
    'for internal 8MHz
    Define CONF_WORD = 0x3f50
    Define CONF_WORD_2 = 0x3ffc
    Define CLOCK_FREQUENCY = 8
    OSCCON = 0x70 'define internal 8MHz clock
    'Variable Declarations
    Const trisa1 = %11111111
    Const trisb1 = %01011110
    Symbol io_pwm = RB0 'PWM output
    Symbol io_tx232_ir = RB5 'rs-232 IR output
    'wireless interface constants
    Const beam_char = 0xaa 'RS232 transmission character
    Dim _true As Bit
    Dim _false As Bit
    _true = True
    _false = False
    'Main Program
    main:
    WaitMs 3000
    Call init()
    While _true
    Serout io_tx232_ir, 1200, beam_char
    WaitMs 25
    Wend
    End
    Proc init()
    AllDigital
    TRISA = trisa1
    TRISB = trisb1
    'pwm settings
    '>>>pwm period to 40kHz
    PR2 = 49
    '>>>pwm duty cycle to 50%
    CCPR1L = 25 'using 8-bit mode (for 10-bit mode, 100 would be written to CCPR1L:CCP1CON<5:4>)
    '>>>pwm tmr2 prescaler 1:1 (for 40kHz)
    T2CON.T2CKPS1 = 0
    T2CON.T2CKPS0 = 0
    '>>>pwm tmr2 enable
    T2CON.TMR2ON = 1
    '>>>pwm enable
    CCP1CON.CCP1M3 = 1
    CCP1CON.CCP1M2 = 1
    WaitMs 1000
    End Proc
    Code - Receiver:
    '* PIC16F88 * IR Receiver Test Bed *'
    'Title: IR Receiver
    'Description: This program uses MCU to detect an IR transmission. IR transmission is received by IR module, inverted, and then received by HW UART.
    'Pin Allocation:
    'PIN# Main_Fn
    'RA0 -> not used
    'RA1 -> not used
    'RA2 -> not used
    'RA3 -> not used
    'RA4 -> not used
    'RA5 -> not used
    'RA6 -> not used
    'RA7 -> not used
    'RB0 -> LED Output
    'RB1 -> not used
    'RB2 -> RS232 IR input (HW_UART-RX)
    'RB3 -> not used
    'RB4 -> not used
    'RB5 -> not used
    'Usage Information:
    'IR Baud rate (HW UART): 1200bps
    'IR receiver idles "high", active "low"
    'Version Info:
    'v1
    '->RS-232 IR receive
    'for internal 8MHz
    Symbol io_led = RB0 'LED output
    Symbol io_rx232_ir = RB2 'rs-232 IR input
    Const tmr1h_preload = 0x3c 'Timer1 preload for 100msec tick rate
    Const tmr1l_preload = 0xb1 'Timer1 preload for 100msec tick rate
    Dim _sample_received As Bit
    Dim _true As Bit
    Dim _false As Bit
    _true = True
    _false = False
    'Main Program
    main:
    WaitMs 1000
    _sample_received = 0
    Call init()
    'hwuart setup
    Hseropen 1200
    'preload tmr1 for 100msec tick rate
    TMR1H = tmr1h_preload
    TMR1L = tmr1l_preload
    'enable tmr1
    T1CON.TMR1ON = 1
    'enable interrupts
    INTCON.GIE = 1
    INTCON.PEIE = 1
    PIE1.TMR1IE = 1
    PIE1.RCIE = 1
    Dim _char As Byte
    While _true
    Wend
    End
    Proc init()
    AllDigital
    TRISA = trisa1
    TRISB = trisb1
    'tmr1 settings
    T1CON.TMR1CS = 0 'tmr1 from internal source
    'tmr1 prescale to div-by-4
    T1CON.T1CKPS1 = 1
    T1CON.T1CKPS0 = 0
    Low io_led
    WaitMs 100
    High io_led
    WaitMs 100
    Low io_led
    WaitMs 1000
    End Proc
    On Interrupt
    'for tmr1 overflow
    If PIR1.TMR1IF Then
    If _sample_received Then
    Low io_led
    Else
    High io_led
    Endif
    PIR1.TMR1IF = 0
    Endif
    'for hwuart character in buffer
    If PIR1.RCIF Then
    Dim _char As Byte
    Hserget _char
    If _char = beam_char Then
    _sample_received = 1
    Else
    Endif
    PIR1.RCIF = 0
    Endif
    Resume
    Comments
    rahila, December 08, 2010
    sir, i think you can help me in clearing my doubts,may be foolishness, regarding propagation of waves... Its known that as the frequency of waves increases the distance it can travel also increases,then why do we need to keep two mobiles close to each other while sending datas through bluetooth technology... Is not bluetooth technology is using high frequency radio waves?
    languer, December 08, 2010
    Completely unrelated to the article, but i'll provide a quick answer. Actually it's opposite, the higher frequencies suffer more attenuation through distance of travel (because of their shorter wavelengths) - Friis equation should be a starting point for this. For bluetooth in particular; it has as much to do with frequency as it has to do with the very low transmit power - to meet regulatory requirements.
    ripingz, February 20, 2012
    [QUOTE=languer;bt362]Completely unrelated to the article, but i'll provide a quick answer. Actually it's opposite, the higher frequencies suffer more attenuation through distance of travel (because of their shorter wavelengths) - Friis equation should be a starting point for this. For bluetooth in particular; it has as much to do with frequency as it has to do with the very low transmit power - to meet regulatory requirements.[/QUOTE] what is ir beam function..i'm still dont get it.. why u give 2 transmitter circuit....
EE World Online Articles
Loading
