- Blog entry posted in 'tekronix 2235a', June 06, 2015.
i bought a tektronix scope from ebay "not working use fro parts" I got for $50 dollars. When I got the only work on it was leds and no trace. I download the service manual and followed the flow chart. I started when no trace part. It told to press find the beam button and so I did. What luck it had a trace but when adjusted the position controls and still no no trace. The next step check all the voltages and i found that all voltages was correct and nothing. Finally the last thing a did was adjust crt bias and the trace finally appeared so I calibrated. i start calibrating every thing that needed calibrate. I notice when i used both channels one trigger and the other wont and I went the selector switch form lf/hf rej to normal the switch jammed up and broke. I need a replacement switch is a 4 position level slide switch. on the parts layout the part number is s392 I think .
I need a new switch does any no where I can get one or how fix the switch.
larry
KeepItSimpleStupid, June 09, 2015
There are three places for Tek parts: Sphere in Canada, qservice in Greece and ask in the Yahoo Tekscopes group.
KeepItSimpleStupid, July 05, 2015
Sphere [URL]http://www.sphere.bc.ca/test/tek-parts/tekparts9.html[/URL] has one as of July 5. 2015. You have to convert the designator to the part number and look in the SM.
