While looking for a new variable voltage bench PS I ran into Sparkfun's Power Board Kit to convert an ATX supply to a bench supply. One does not need a kit to do this but fuse holders and binding posts in the kit cost nearly what the kit did so I gave it a try.
I built the PCB and mounted it to a 200W ATX PSU pulled from a 400MHz machine.
![ATX PSU 001_C.JPG ATX PSU 001_C.JPG](https://www.electro-tech-online.com/data/attachments/43/43582-a71e0a1e6f9671f55b5e2d58f448c081.jpg)
A bench supply should have short circuit protection. This unit uses 5A 125V glass fuses which run about 50 cents a pop. (pun intended)
As noted in the sparkfun comments the connectors do not use standard spacing but I do not much care about that. For reasons I do not understand there is no switch to the soft power line on the PSU, that would have been nice. The plastic spacers need to be 1/4" longer to keep the tips of the binding posts from contacting the PSU case.
My old ATX PSU has a 20 pin connector and the kit uses a 24 pin connector. It works but the latch on the connector does not line up. the 20 pin version of the PSUs have a -5V line that is a NC in the 24 pin versions.
I had a bit of a fuss getting a load that would let the PSU startup. I used a resistor on the 5V output and that worked until I plugged the PSU case fan into the PSU PCB. Removed the resistor and it did not work with the fan in place. Without the resistor, but with the fan on the 5V rail it works. So I am going with that and do not much care why. I need to remove the PCB to do a decent job of connecting the fan wire. Maybe add a switch.
I would give the kit a thumbs up, It is good so far as it goes.
