▓How to increase the amperage of the tp4056 module to 3A?▓
electronium
Greetings to the colleagues of the forum
If we want to get a higher amp from a single tp4056 module, for example, what circuit should we add to the module, can we? How is the circuit and its schematic?
I don't think you should be thinking along those lines. This chip was designed for a specific purpose and there is literally zero indication that it can be used outside of those guidelines. At least that is the way I read the datasheet. Do you know something that I don't? There is probably an OTS microcontroller that you could use to build a more capable unit, but charging is not a simple process and there are numerous safety concerns to be aware of. You should check Battery University for a rudimentary look into what you are up against.
Don't shoot yer' eye out kid!
ETA: where the admonition came from
