yce_kelvin
hi, i am new on PIC.. i got a project which used PIC16C57C which are use for timer counting.
The portC as and output of 4 seven segment display and also the input of a time setting switch.
so, initially, i write the program, i configure the port c at output.. but then after i display the '0000' on 7 segment, i need to proceed to process 2 which detect the input of port c, to check the switch which got press and got signal in to MCU. So, how can i configure the port c bo be input??
what metter i try to configure it for eg:
movlw b'00001111' ; -- port c pin 0,1,2,3 as input
movwf trisc
btfsc portc,0
goto result
but it still not functioning..
is that possible for a port that change from output to input suddenly?
my other I/O port already fulfill with other application... any one can give me some suggestion? thank you very much...
wish some one can reply me as soon as posible.. thanks.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
movwf trisc
btfsc portc,0
goto result
