12 Bit Parallel to Serial conversion 16F627
Horizon
I'm building a tide level data logger. I've finished the electronics hardware. It can measure a tidal range of 4 metres with a resolution of 1 mm.
The output is a 12 bits of parallel data.
I need to send this over a wired serial conection. Data rate can be slow since it only has to be read once every few minutes.
I'm trying to use the UART in a 16F627. The parallel data is input on Port A for the LS 8 bits. The most significant 4 bits are on RB 4,5,6,7
I can get the UART to send fixed constants or text (Hello World) and I can read it over the serial link. However, I just can't seem to read the data from the input pins. I always seem to end up just sending zero whatever data I put on the inputs. It's a long time since I did any of this stuff, I think I'm missing something obvious, but as an older person, the obvious gets harder and harder to spot.
Any help would be appreciated.
'12 bit Parallel to Serial by Derek Hodge
'11 Oct 2013
'Device 18-pin 16F627A
'Inputs RA0 - RA7 , RB4, RB5, RB6, RB7
'serial out TX Pin 8
Define CONFIG = 0x3f18
Define CLOCK_FREQUENCY = 4
AllDigital
Hseropen 4800
TRISA = 0xff  'Set Port A as input.  Have also tried this using CONFIGPIN but same result
TRISB = 0xf0  'Set  most significant 4 bits of PORT B as input
Dim ls8 As Byte  'LS 8 bits
Dim ms4 As Byte  'MS 4 bits
loop:
PORTA = ls8
PORTB = ms4
Low ms4.0  'Make sure LS bits are 0
Low ms4.1
Low ms4.2
Low ms4.3
ms4 = ShiftRight(ms4, 4)  'Move the data bits from most significant positions to LS positions
Hserout ls8, ","
Hserout ms4, CrLf
WaitMs 500
Goto loop
You appear to be writing variables (ls8 & ms4) to your port pins.
Try changing,
PORTA = ls8
PORTB = ms4
To,
ls8=PORTA
ls4=PORTB
Hi Mike,
now it's official "I'm an idiot"!
Amazing how hard it is to spot your own mistakes, even when it's obvious to someone else.
I just tried it and now everything is fine.
Thanks again for your help.
Derek
Hi Mike,
Derek
We've all done it. It's easy to get blinded when looking for why it doesn't work. I find that explaining how code works to someone else works wonders for spotting these kind of things, even a teddy bear works.
