I need a one way diode to use in a 12 VDC automotive application to prevent back-flow on a reversing polarity 12 V-5 amp load actuator,the actuator runs to a limit switch & stops, reversing the polarity runs the motor in reverse until limit switch stops it,,,, what to use?
Purpose intended, is to use radiator water temperature to open and close an air intake door , the plan is to use these controllers but I think I need 2 diodes in the mix.
Thanks for any help
Silvio
Thanks for any help
Silvio
