budget minded
this isn't exactly an "automotive" etc. application, but it will be a 12 volt system, just lacking an alternator. there are a few issues i need to iron out though. it was originally supposed to be a 36v system, but that created a lot of problems eg. separate batteries for an EQ/crossover or using passive low pass inline filters which seemed to drive a lot of people nuts, and the dearth of 36v power meters amongst other issues.
just now, i took the plunge on a Planet Audio BB1200.4 @ 4 channel amp for several reasons... it should be more rugged mounted under the trailer than the sure modules i originally intended to use, it can be configured as a 3 channel sub sat amp with built in crossovers, has level setting pots for both front and rear (sub) channels and the 18dB bass boost option will be especially useful when i start rolling with only a pair of 8 inch 96dB DJ speakers until i biamp with 4 x 12" subs. it's a very flexible amp that solves a lot of problems, is efficient class D, is reasonably light and compact, already has RCA inputs and probably beefier terminals than the little sures and i just like its clean simple lines, blue illuminated logo, and i like the tree hugger friendly brand name even if the amp will be out of sight.
the DJ speakers are rated at 8 ohms, so i'm expecting lower than rated output, maybe 75wpc, on the mains, but that should be a very friendly load on the amp and was also planning on an 8 ohm load on the bridged mono sub channel, instead of going 2 ohm as i'm more concerned about SQ, run times and durability than SPLs.
the issues i'm looking to resolve are wiring related.
1. i'm planning on using a pair of 12v 35aH lead acid batteries in parallel for a 12v 70aH system. i planned on using a pair of positive and negative distribution blocks to link the two batteries and use a 70a+ circuit breaker as a power switch along with using an inline fuse, if necessary, to protect the amp, though it has its own fuses. would you recommend an inline fuse too, and if so, what amperage?
2. i planned on creating terminals after the distribution blocks so that i could charge both batteries at the same time. are there any issues about doing that i should worry about, or special needs i'd have with a charger. i planned on trickle charging the system to give the batteries an easy load. i was going to have to create 3 individual terminal pairs at 1 for each battery along with 3 power meters when i was planning on a 36v system, but this seems to be the much easier route. the only issue i can imagine with parallel charging 2 batteries would be voltage balancing them as is done with battery packs.
3. i plan on using a power meter, but read in one review that a user put a fuse on his meter. i planned on tapping into the circuit after the breaker so the meter is unpowered when everything is turned off. should i use a fuse for the meter too, and if so, what rating. they all seem to draw under 20 milliamps. i would think that a 1 amp load/fuse wouldn't fry a meter. down the road, pun intended, i also intend to add a 12v LED lighting circuit. i know the basics about needing resistors for LED circuits and could handle doing the calculations, but would i also need to fuse that too? one of the things i "learned" years ago is that regardless of how much current you have, a component/circuit can only pass as much current as the components allow, but since then have seen that overvolting an amp can fry it and i wonder if overamping can too.
CORRECTION: i'll be using the 4 ohm and not the 8 ohm version as it's 4dB more efficient
4. i'm planning on eventually using 4 Goldwood GW-12PC-4 12" woofers because they're the most efficient, especially at 30Hz woofers i could find for the 1.2 cubic feet, I THINK, sealed enclosures i intend to use. i did thiele small calculations on a bunch of mostly dayton & goldwood woofers, and the goldwoods had both the highest output at 30Hz by 9dB (!!!) compared to everything else in the enclosures as well as having a "perfect" system Q of .707 with hopefully extra tight bass from the small air spring.
they're rated at 225w continuous at 4 ohms. i was planning on wiring them series/parallel to maintain a 4 ohm load. as i understand it, speakers in series can only take their individual rated output as they're in a "closed circuit", but if they're also wired in parallel, can't they split the power eg. 2 x 225w on a 400w amp?
my understanding of electronics as far as circuits go is basic so i'd appreciate it if the experts here would correct any errors, if any, i'm about to make or add input on anything i've overlooked. thank you in advance for your time and consideration.
