I think the symmetrical Klystron injects energy into the Ultra high capacity magnetron which in turn excites the high density flux capacitor thereby generating sufficient current to the anti-matter overdrive thus achieving final output of 1000w. The cd4011 drives the circuit active LED.
You forgot to mention, if he plugs the 4011 in the wrong way around, it may cause a tear in the space time continuum which could lead to warping of subspace which may in turn create a black hole.![]()
Yes, this is true and I neglected to mention this warning as I assumed the OP knew to use the required Omicron space time compression thermal unit.
I think we both need councelling.![]()
There is a distinct possibility that when the new LHC (Large Hadron Collider) is turned on in September that the Earth could be destroyed by a man made black hole type event....
Concerns have been raised regarding the safety of the Large Hadron Collider (LHC) on the grounds that high-energy particle collisions performed in the LHC might produce dangerous phenomena, including micro black holes, strangelets, vacuum bubbles and magnetic monopoles.![]()
Apparently they have not heard about the obvious Omicron space time compression thermal unit precaution either
QUOTE]
That's the thing that will prevent the end of the world by the LHC
I;ve seen it on a documentry on the ZBD channel (Zaytar Beam Download)
Although the didn't use 4011 in there but 4001 so the risk is reversed
Robert-Jan
You guys are mean, you didn't give him a circuit diagram!!
here's one:
http://magnet.c2b2.columbia.edu/i/diagram_03.gif
Remember, this is a LEFT HANDED diagram!!, if you're right handed, you'll need to make appropriate adjustments.
And whatever you do, NEVER build this project after the full moon. I can't count how many times bad things have happened because people built it after the full moon. Morons.
I think what we're doing qualifies as "biting the newbie."
Because they aren't satisfied with their power reliability, and they don't understand the limitations of that big heavy 12V battery in their auto or truck.Why do noobies in 3rd world countries want to make a high powered inverter??
Not in the output stage.Do you think the Large Hadron Collider uses a CD4011?
