12V DC to 240Ac Power supply
Deeler
Hi there
I do Mobile repairs on farm equipment.
I am looking for a circuit that i can use on a 12V car battery to convert it to 230-240V AC. Want to run a portable drill and grinder and if any off you know how i can do welding with an altenator.
It's called an inverter and can be bought pretty cheaply from automotive stores.
When I worked in a quarry, there was a portable arc welding set fitted to a Land Rover.
It was a generator fitted in place of the middle front seat, with a power-take-off from the gearbox.
The generator was about 30cm x 30cm x 40cm. It needed 2000 rpm on the engine to run, and the bonnet left open to help cool the engine.
I would suggest you buy a welder that runs on petrol or diesel, or you are going to have to carve up your vehicle in a significant way.
