Hello folks - Looking to build a 12v turn table circuit that will allow the turn table to go to home position after power is turned off. S1 provides power to the motor, S2 (controlled by the hall effect) is in parallel. When S1 is turned off, power should still be applied to the circuit to keep the motor turning until the hall effect says that it has reached the home position. Switch S2 will then turn off. I am hoping that S2 can be a transistor not a relay. DC motor has brushes and will draw 10-15 amps.
Any help would be appreciated.
Thankx in advance
Glenn
Thankx in advance
Glenn
