Hello
I have a motorhome whose refrigerator uses a 24Vac "swing motor". A swing motor is basically a solenoid connected to the piston so it vibrates with the AC waveform in a linear motion rather than rotary. Here is a link on the swing motor for your info:
The unit had a transformer with 120V, 24V and 12VCT windings. When running on 12Vdc, it used a square-wave multivibrator driving the 12V. This circuit is burned out but the transformer is Ok. I've made up a PIC circuit with several temperature sensors to make it more modern. The PIC also drives a couple power FETs into the 12Vct winding to get 24Vac to run the swing motor. Everything works fine but the 60Hz square wave (stepped square ware) makes a buzz noise that is very irritating. I'd like to modify it to get the wave closer to a sine wave.
I have increased the switching frequency and tried my hand at PWM.
Anyone have any ideas?
Before everyone tells me to run out and buy a commercial sine wave inverter, let me say I have plenty of them lying around in my shop. We have used them (attempted more like it) for battery backup systems in our work and they have many drawbacks. example:
-Intermittently or constantly refusing to start with a load connected.
-shutting down well before the battery is low.
in other words we use them as door stops now.
Also the original inverter is no longer available (it likely buzzed too) and a new fridge is 1500.00
