16f628 and mplab
zaro
Hi
I am new in pics and MCs, with poor electronics knowledge.
I run my 1st program and...
1) receive the message:
"Register in operand not in bank 0. Ensure that bank bits are correct" at lines: "movwf TRISB, movwf TRISA".what does it mean? something wrong?
2) I used the options: "MPLAB SIM, PICSTART Plus". is it ok?
3) while runing the debuger i notice that the registers change into the expected values, but there is no effect at the output pins. They show steady 5+ volt (of coarse i am runing a blinking led program). Why? Whats wrong?
4) Despite this voltage, there is no current at all. How can?
TRISA and TRISB stays in bank1, therefore, to write to TRISA or TRISB, you must access to bank1.
BSF status, rp0 ; bank1
; write to TRISA and TRISB here
;then
BCF status, rp0 ; return to bank0
It's oki.
Because you didn't configure the outputs for the pins of ports.
If you only write
MOVLW b'00000000'
MOVWF TRISB ; all portB are outputs
it's not effected.
You have to write
BSF status, rp0
MOVLW b'00000000'
MOVWF TRISB
BCF status, rp0
The output current is 25mA
Check section 3.0 MEMORY ORGANIZATION in the Datasheet.
In figure 3-2 show the data memory map of the 16f627-28,
for example TMR0 is in bank0 so you have to tell mplab to switch to bank0, if you want to modify the trisa register you need to switch to bank1.
Personally I always use "BANKSEL" instead to jiggle with the rp bits.
Example
           BANKSEL   trisa
           movlw     b'00000000'
           movwf     trisa
           BANKSEL   porta
           movlw     .11
           movwf     portb
Expert's say's, go use the rp bit's :!:
STEVE
Do note that BANKSEL commands are only possible when writing relocatable code. When writing absolute code it won't work.
Take a look at the pic's datasheet under the header "data memory organization" (section 3.2). You will see that the data memory or RAM is divided into banks. Files like PORTA and PORTB are in bank0, while files like TRISA and TRISB are in bank1. This means you have to switch to the right bank before you can access a variable. You do this by playing with the bits RP0 and RP1 of the file STATUS like shown in the datasheet.
The message you get 'Register in operand not in bank 0. Ensure that bank bits are correct' is a warning (not an error) from the compiler telling you to make sure you switched to the right bank. You will always get this message, even when your code is correct. You can suppress the message with a line "ERRORLEVEL -302" at the top of your code.
MPLAB sim is the built in simulator of MPLAB. It allows you to 'virtually' run your code on your pc to see what happens. Quite handy for timing loops with the stopwatch and testing some math code for example.
need a scematic of how your pic is connected and a listing of your software to help you further.
