16F628 EEP Read/Write
tom3000
having ruff time reading and writing to eeprom .....
for some strange reason it's intermittant....i have my read/write procedures in a short program....works perfectly fine......
i stick the exact same code into a larger program....it doesnt work right.....
anybody had something like that happen to them ??? what's the damn solution here
fact is the larger program is over 1k, has more 'CALLS', 'jmps' ...i also put short delay after every read/write cause it seemed to work better on my old 16f84's
Instead of delaying after the write, how about you wait until the EECON1,WR bit is cleared before writing.
If you're trying to write to the eeprom in both the main code and in the isr (assuming you're using it) you may have problems with the timing as well.
no im not using int service routine at all if that's what you mean by isr
im using the simple
EEREAD
blah
blah
blah
retlw 0
EEWRITE
blah
blah
blah
retlw 0
both are CALLED from various other procs....AND IT DOESNT WORK RIGHT for READS either !!!!! (in the longer program of course)
in the short program it works perfectly fine, the short program is about 100 bytes long, no more
WTF ? ? ? ? ? ? ? ? ? ? ? ? ?
Post the code for your ee read and write routines. It's very odd that the reads don't work properly. Have you decoupled the power supply with a capacitor close to the pic?
im using the simple
EEREAD
blah
blah
blah
retlw 0
EEWRITE
blah
blah
blah
retlw 0
WTF stand for Watchdog Timer Function
Hope this help/
HAhahahahahahaaaaa
Look for title effect at bottom....
Can u take a look of my example? I used more calls in pic16F628A Reasoning is why i used more procedure events is preventing links errors.
https://www.electro-tech-online.com...to-left-right-fade-in-out-wipe-in-out.103240/
the code is STRAIGHT OUT OF the MicroChip BOOK....only difference i add 25microsecond delays after each read/write call
okay thanks for those who replied....i got it going....was just being reckless for not double checking the whole big program....some corrections were needed with the EEDATA and EEADR....forgot that in the 628's those 2 can only be accessible from bank1, in F84's 1 can access them from both 0 and 1
