akg
Hello all
i was just trying to i/f the lcd module with a 16f628a , code below, most of them from nigel's site
the init routine was based on an Hd44780 pdf file . i have not connected the backlight pins. the contrast pin is directly connected to vcc . the problem is the lcd is not showing 'any' sign of life. :? can i assume the lcd to be dead or is there something wrong in the code/init sequence ?. any help would be appreciated.
thanks
list p=16f628A
#include <p16F628A.inc>
; errorlevel -302
__CONFIG _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT
cblock 0x20
count1
counta
countb
endc
LCD_CTRL equ PORTA
LCD_PORT equ PORTB
LCD_RS equ 0x0
LCD_RW equ 0x1
LCD_E equ 0x2
ORG 0x000
clrf INTCON
call Delay255
call Delay255
call Delay255
call Delay255
movlw 0x07
movwf CMCON
clrf PORTA
clrf PORTB
bsf STATUS,RP0
clrf TRISA
clrf TRISB
bcf STATUS,RP0
call LCD_Init
call Delay100
movlw 'A'
call LCD_Char
movlw 'B'
call LCD_Char
movlw 0xC0
call LCD_Cmd
movlw 0x1
call LCD_CharD
lp goto lp
LCD_Init
bcf LCD_CTRL,LCD_RW
bcf LCD_CTRL, LCD_E
call Delay100
movlw 0x38
call LCD_Cmd
movlw 0x38
call LCD_Cmd
movlw 0x38
call LCD_Cmd
movlw 0x38
call LCD_Cmd
movlw 0x08
call LCD_Cmd
movlw 0x01
call LCD_Cmd
movlw 0x06
call LCD_Cmd
movlw 0x02
call LCD_Cmd
movlw 0x0F
call LCD_Cmd
movlw 0x80
call LCD_Cmd
retlw 0x0
LCD_Cmd
movwf LCD_PORT
bcf LCD_CTRL, LCD_RS ;RS line to 0
call Pulse_e ;Pulse the E line high
call Delay50
retlw 0x0
LCD_CharD
addlw 0x30
LCD_Char
movwf LCD_PORT
bsf LCD_CTRL,LCD_RS
call Pulse_e
call Delay50
retlw 0x0
Pulse_e
bsf LCD_CTRL, LCD_E
nop
nop
nop
bcf LCD_CTRL, LCD_E
retlw 0x00
Delay255
movlw 0xff ;delay 255 mS
goto d0
Delay100
movlw d'100' ;delay 100mS
goto d0
Delay50
movlw d'50' ;delay 50mS
goto d0
Delay20
movlw d'20' ;delay 20mS
goto d0
Delay5
movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
END ; directive 'end of program'
thanks
