I attempted to program a PIC16F628A with a programming kit (AS3150v2) and micropro22 software I got from Quasar electronics but I encountered the following problems:
1) If I click on the program tab, the following comes up 'received data error....about to apply reset'
2) If I click on the verify tab, the following comes up:
EEPROM error at 0x004A
Good 0x00
Bad 0xFF
3) If I place the IC in my circuit anyway, the following happens
. The IC becomes extremely hot within seconds
. The LEDs of PORTB comes on and remain on irrespective of the alterations I make to my codes in the MPASM.
This is my first hands-on. new IC, new programmer, the codes are copied from Nigels tutorials so what could be wrong!
Below is the code I tried to program.
Tutorial 1.2 - Nigel Goodwin 2002
LIST p=16F628 ;tell assembler what chip we are using
include "P16F628.inc" ;include the defaults for the chip
__config 0x3D18 ;sets the configuration settings (oscillator type etc.)
cblock 0x20 ;start of general purpose registers
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
endc
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
bsf STATUS, RP0 ;select bank 1
movlw b'00000000' ;set PortB all outputs
movwf TRISB
movwf TRISA ;set PortA all outputs
bcf STATUS, RP0 ;select bank 0
Loop
movlw 0xff
movwf PORTA ;set all bits on
movwf PORTB
nop ;the nop's make up the time taken by the goto
nop ;giving a square wave output
call Delay ;this waits for a while!
movlw 0x00
movwf PORTA
movwf PORTB ;set all bits off
call Delay
goto Loop ;go back and do it again
Delay movlw d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
end
Good 0x00
Bad 0xFF
endc
movlw 0x07
movwf TRISB
Loop
movlw 0xff
movwf PORTB
movlw 0x00
movwf PORTA
call Delay
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
end
