birdman0_o
Active Member
Hey guys, I've been playing around tonight and I've run into a problem with Bit 4 of the A register. It is set as output and I am turning it on high, but it is not turning it on. I can't imagine TOCKI being set, which is what is shared with that pin. I've never had this problem before!
Here is my code...Thanks ahead of time![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
; Author : Mike Baird
; Program : Template
; Date :
; Table
; (f) Left Top = bit5
; __ (a) Top = bit0 (b) Righ Top = bit1
; |__| (g) Middle = bit6 (e) Left Bot = bit4
; |__| (d) Bottom = bit3 (c) Righ Bot = bit2
;0 = b'00111111'
;1 = b'00000110'
;2 = b'01011011'
;3 = b'01001111'
;4 = b'01011010' <-
;5 = b'01110011' <-
;6 = b'01110111' <-
;7 = b'00101010' <-
;8 = b'01111111' <-
;9 = b'01111010' <-
List P=16F628
#include "P16F628.INC"
__config _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_ON & _LVP_OFF & _CP_OFF & _MCLRE_OFF
;*** Cblock ***
CBLOCK 0x20
d1 ;
d2 ;
Number1 ;
Number2 ;
Number3 ;
Number4 ;
ENDC
;*** Defines ***
#Define Bits PORTA,0
#Define Clock PORTA,7
#Define Latch PORTA,6
;*** Macro ***
HC595 MACRO Var,Var1
Local Loop ; Local Label
MOVLW .8 ; Transfer 8 bits
MOVWF Var1 ; Initializing counter
Loop
RLF Var,f ; Rotate "Var" one place to the left
BTFSS STATUS,C ; Is carry 1?
BCF Bits ; If not set data line to 0
BTFSC STATUS,C ; Is carry 0?
BSF Bits ; If not set data line to 1
BSF Clock ; Generate one clock
BCF Clock ;
DECFSZ Var1,f ; Has 8 bits been sent?
GOTO Loop ; If not, repeat
BSF Latch ; If all 8 bits have been sent, set latch
BCF Latch
ENDM
;*** START OF RAM ***
ORG 0x000 ; Start of program vector
GOTO Start ;
ORG 0x004 ; Interrupt vector
; Goto ISR
Start
MOVLW 0x07 ; Turn comparators off and enable pins for I/O
MOVWF CMCON ; ^
CLRF PORTA ; PortA all low
CLRF PORTB ; PortB all low
BSF STATUS,RP0 ; Bank 1
MOVLW b'00100000' ;
MOVWF TRISA ; PortA all output except MCLR
CLRF TRISB ; PortB all output
BCF STATUS,RP0 ; Bank 0
Main:
BCF PORTA,4
BSF PORTA,1
MOVLW b'00111111'
MOVWF Number1
HC595 Number1,Number2
Call Delay
BCF PORTA,1
BSF PORTA,2
MOVLW b'00000110'
MOVWF Number1
Call Delay
BCF PORTA,2
BSF PORTA,3
MOVLW b'01011011'
MOVWF Number1
Call Delay
BCF PORTA,3
BSF PORTA,4
MOVLW b'01001111'
MOVWF Number1
Call Delay
GOTO Main
; *** Delay ***
Delay
MOVLW d'255'
MOVWF d1
MOVLW d'255'
MOVWF d2
D2
DECFSZ d1,F
GOTO D2
DECFSZ d2,F
GOTO D2
RETURN
END
; That's all folks!
