Analogue Robot
Hello all.
1) I am trying to get an HD4470U-type LCD display to work in 4-bit mode with a PIC 16F84A.
2) The project builds correctly in MPLAB and burns onto the PIC, but the LCD remains dead: no response at all from the LCD.
3) Can anyone tell me what to do to get it working, please?
I am using the code provided in "Microcontroller Programming the Microchip PIC", 2007, Sanchez and Canton, CRC Press, pp.327-338.
The code specifies an RW line: my development board does not have one, so I have made the following connections, per the circuit diagram (p.305):
E - RA1
RS - RA2
D4 - RB4
D5 - RB5
D6 - RB6
D7 - RB7
Here is the code, copied from MPLAB:
; File name: LCDTest3.asm
; Date: April 16, 2006
; Author: Julio Sanchez
; Processor: 16F84A
; Description:
; Program to exercises 4-bit PIC-to-LCD interface.
; Code assumes that LCD is driven by Hitachi HD44780
; controller and that the display supports two lines
; each one with 16 characters. The wiring and base
; address of each display line is stored in #define
; statements. These statements can be edited to
; accomodate a different set-up.
; Program uses delay loops for interface timing.
; WARNING:
; Code assumes 4Mhz clock. Delay routines must be
; edited for faster clock
; Displays: Minnesota State, Mankato
; switches
; Switches used in __config directive:
; _CP_ON Code protection ON/OFF
; * _CP_OFF
; * _PWRTE_ON Power-up timer ON/OFF
; _PWRTE_OFF
; _WDT_ON Watchdog timer ON/OFF
; * _WDT_OFF
; _LP_OSC Low power crystal occilator
; * _XT_OSC External parallel resonator/crystal ocillator
; _HS_OSC High speed crystal resonator (8 to 10 MHz)
; Resonator: Murate Erie CSA8.00MG = 8 MHz
; _RC_OSC Resistor/capacitor ocillator
; | (simplest, 20% error)
; |_____ * indicates setup values presently selected
; setup and configuration
processor 16f84A
include <p16f84A.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
; constant definitions
; for PIC-to-LCD pin wiring and LCD line addresses
#define E_line 1 ;|
#define RS_line 2 ;| -- from wiring diagram
#define RW_line 3 ;|
; LCD line addresses (from LCD data sheet)
#define LCD_1 0x80 ; First LCD line constant
#define LCD_2 0xc0 ; Second LCD line constant
; Note: The constant that define the LCD display line
; addresses have the high-order bit set in
; order to faciliate the controller command
; variables in PIC RAM
; Reserve 16 bytes for string buffer
cblock 0x0c
strData
endc
; Leave 16 bytes and Continue with local variables
cblock 0x1d ; Start of block
count1 ; Counter # 1
count2 ; Counter # 2
count3 ; Counter # 3
pic_ad ; Storage for start of text area
; (labeled strData) in PIC RAM
J ; counter J
K ; counter K
index ; Index into text table (also used
; for auxiliary storage)
store1 ; Local temporary storage
store2 ; Storage # 2
endc
; program
org 0 ; start at address
goto main
; Space for interrupt handlers
org 0x08
main:
movlw b'00000000' ; All lines to output
tris PORTA ; in port A
tris PORTB ; and port B
movlw b'00000000' ; All outputs ports low
movwf PORTA
movwf PORTB
; Wait and initialize HD44780
call delay_5 ; Allow LCD time to initialize
; itself
call delay_5
call initLCD ; Then do forced initialization
call delay_5 ; Wait again
; Store base address of text buffer in PIC RAM
movlw 0x0c ; Start address for buffer
movwf pic_ad ; to local variable
; first LCD line
; Store 16 blanks in PIC RAM, starting at address stored
; in variable pic_ad
call blank16
; Call procedure to store ASCII characters for message
; in text buffer
movlw d'3' ; Offset into buffer
call storeMSU
; Set DDRAM address to start of first line
call line1
; Call procedure to display 16 characters in LCD
call display16
; second LCD line
call delay_5 ; Wait for termination
call blank16 ; Blank buffer
; in text buffer
movlw d'1' ; Offset into buffer
call storeUniv
call line2 ; DDRAM address of LCD line 2
call display16
; done!
loopHere:
goto loopHere ;done
; initialize LCD for 4-bit mode
initLCD:
; Initialization for Densitron LCD module as follows:
; 4-bit interface
; 2 display lines of 16 characters each
; cursor on
; left-to-right increment
; cursor shift right
; no display shift
; set command mode |
bcf PORTA,E_line ; E line low
bcf PORTA,RS_line ; RS line low
bcf PORTA,RW_line ; Write mode
call delay_125 ; delay 125 microseconds
; FUNCTION SET |
movlw 0x28 ; 0 0 1 0 1 0 0 0 (FUNCTION SET)
; | | | |__ font select:
; | | | 1 = 5x10 in 1/8 or 1/11 dc
; | | | 0 = 1/16 dc
; | | |___ Duty cycle select
; | | 0 = 1/8 or 1/11
; | | 1 = 1/16 (multiple lines)
; | |___ Interface width
; | 0 = 4 bits
; | 1 = 8 bits
; |___ FUNCTION SET COMMAND
call send8 ; 4-bit send routine
; Set 4-bit mode command must be repeated
movlw 0x28
call send8
; DISPLAY AND CURSOR ON |
movlw 0x0e ; 0 0 0 0 1 1 1 0 (DISPLAY ON/OFF)
; | | | |___ Blink character at cursor
; | | | 1 = on, 0 = off
; | | |___ Curson on/off
; | | 1 = on, 0 = off
; | |____ Display on/off
; | 1 = on, 0 = off
; |____ COMMAND BIT
call send8
; set entry mode |
movlw 0x06 ; 0 0 0 0 0 1 1 0 (ENTRY MODE SET)
; | | |___ display shift
; | | 1 = shift
; | | 0 = no shift
; | |____ cursor increment mode
; | 1 = left-to-right
; | 0 = right-to-left
; |___ COMMAND BIT
call send8
; cursor/display shift |
movlw 0x14 ; 0 0 0 1 0 1 0 0 (CURSOR/DISPLAY SHIFT)
; | | | |_|___ don't care
; | |_|__ cursor/display shift
; | 00 = cursor shift left
; | 01 = cursor shift right
; | 10 = cursor and display
; | shifted left
; | 11 = cursor and display
; | shifted right
; |___ COMMAND BIT
call send8
; clear display |
movlw 0x01 ; 0 0 0 0 0 0 0 1 (CLEAR DISPLAY)
; |___ COMMAND BIT
call send8
; Per documentation
call delay_5 ; Test for busy
return
; Procedure to delay
; 42 microseconds
delay_125
movlw D'42' ; Repeat 42 machine cycles
movwf count1 ; Store value in counter
repeat
decfsz count1,f ; Decrement counter
goto repeat ; Continue if not 0
return ; End of delay
; 5 milliseconds
delay_5
movlw D'41' ; Counter = 41
movwf count2 ; Store in variable
delay
call delay_125 ; Delay
decfsz count2,f ; 40 times = 5 milliseconds
goto delay
; pulse E line
pulseE
bsf PORTA,E_line ; Pulse E line
nop
bcf PORTA,E_line
return
; long delay sub-routine
; (for debugging)
long_delay
movlw D'200' ; w = 200 decimal
movwf J ; J = w
jloop: movwf K ; K = w
kloop: decfsz K,f ; K = K-1, skip next if zero
goto kloop
decfsz J,f ; J = J-1, skip next if zero
goto jloop
return
; LCD display procedure
; Sends 16 characters from PIC buffer with address stored
; in variable pic_ad to LCD line previously selected
display16
call delay_5 ; Make sure not busy
; Set up for data
bsf PORTA,RS_line ; RS line high for data
; Set up counter for 16 characters
movlw D'16' ; Counter = 16
movwf count3
; Get display address from local variable pic_ad
movf pic_ad,w ; First display RAM address to W
movwf FSR ; W to FSR
getchar
movf INDF,w ; get character from display RAM
; location pointed to by file select
; register
call send8 ; 4-bit interface routine
; Test for 16 characters displayed
decfsz count3,f ; Decrement counter
goto nextchar ; Skipped if done
return
nextchar:
incf FSR,f ; Bump pointer
goto getchar
; send 2 nibbles in
; 4-bit mode
; Procedure to send two 4-bit values to port B lines
; 7, 6, 5, and 4. High-order nibble is sent first
; ON ENTRY:
; w register holds 8-bit value to send
send8:
movwf store1 ; Save original value
call merge4 ; Merge with port B
; Now w has merged byte
movwf PORTB ; w to port B
call pulseE ; Send data to LCD
; High nibble is sent
movf store1,w ; Recover byte into w
swapf store1,w ; Swap nibbles in w
call merge4
movwf PORTB
call delay_125
return
; merge bits
; Routine to merge the 4 high-order bits of the
; value to send with the contents of port B
; so as to preserve the 4 low-bits in port B
; Logic:
; AND value with 1111 0000 mask
; AND port B with 0000 1111 mask
; Now low nibble in value and high nibble in
; port B are al 0 bits:
; value = vvvv 0000
; port B = 0000 bbbb
; OR value and port B resulting in:
; vvvv bbbb
; ON ENTRY:
; w contain value bits
; ON EXIT:
; w contains merged bits
merge4:
andlw b'11110000' ; ANDing with 0 clears the
; bit. ANDing with 1 preserves
; the original value
movwf store2 ; Save result in variable
movf PORTB,w ; port B to w register
andlw b'00001111' ; Clear high nibble in port b
; and preserve low nibble
iorwf store2,w ; OR two operands in w
return
; blank buffer
; Procedure to store 16 blank characters in PIC RAM
; buffer starting at address stored in the variable
; pic_ad
blank16
movlw D'16' ; Setup counter
movwf count1
movf pic_ad,w ; First PIC RAM address
movwf FSR ; Indexed addressing
movlw 0x20 ; ASCII space character
storeit
movwf INDF ; Store blank character in PIC RAM
; buffer using FSR register
decfsz count1,f ; Done?
goto incfsr ; no
return ; yes
incfsr
incf FSR,f ; Bump FSR to next buffer space
goto storeit
; Set address register
; to LCD line 1
; ON ENTRY:
; Address of LCD line 1 in constant LCD_1
line1:
bcf PORTA,RS_line ; RS line low, set up for control
call delay_5 ; busy?
; Set to second display line
movlw LCD_1 ; Address and command bit
call send8 ; 4-bit routine
; Set RS line for data
bsf PORTA,RS_line ; Setup for data
call delay_5 ; Busy?
return
; to LCD line 2
; ON ENTRY:
; Address of LCD line 2 in constant LCD_2
line2:
bcf PORTA,RS_line ; RS line low, setup for control
movlw LCD_2 ; Address with high-bit set
call send8
bsf PORTA,RS_line ; RS = 1 for data
return
; first text string procedure
storeMSU:
; Procedure to store in PIC RAM buffer the message
; contained in the code area labeled msg1
; ON ENTRY:
; variable pic_ad holds address of text buffer
; in PIC RAM
; w register hold offset into storage area
; msg1 is routine that returns the string characters
; an a zero terminator
; index is local variable that hold offset into
; text table. This variable is also used for
; temporary storage of offset into buffer
; ON EXIT:
; Text message stored in buffer
; Store offset into text buffer (passed in the w register)
; in temporary variable
movwf index ; Store w in index
; Store base address of text buffer in FSR
movf pic_ad,w ; first display RAM address to W
addwf index,w ; Add offset to address
; Initialize index for text string access
movlw 0 ; Start at 0
movwf index ; Store index in variable
; w still = 0
get_msg_char:
call msg1 ; Get character from table
; Test for zero terminator
andlw 0x0ff
btfsc STATUS,Z ; Test zero flag
goto endstr1 ; End of string
; ASSERT: valid string character in w
; store character in text buffer (by FSR)
movwf INDF ; store in buffer by FSR
incf FSR,f ; increment buffer pointer
; Restore table character counter from variable
movf index,w ; Get value into w
addlw 1 ; Bump to next character
movwf index ; Store table index in variable
goto get_msg_char ; Continue
endstr1:
return
; Routine for returning message stored in program area
msg1:
addwf PCL,f ; Access table
retlw 'M'
retlw 'i'
retlw 'n'
retlw 'n'
retlw 'e'
retlw 's'
retlw 'o'
retlw 't'
retlw 'a'
retlw 0
; second text string procedure
storeUniv:
; Processing identical to procedure StoreMSU
movf pic_ad,0 ; first display RAM address to W
addwf index,0 ; Add offset to address
; w still = 0
get_msg_char2:
call msg2 ; Get character from table
andlw 0x0ff
goto endstr2 ; End of string
movwf INDF ; Store in buffer by FSR
incf FSR,f ; Increment buffer pointer
goto get_msg_char2 ; Continue
endstr2:
return
msg2:
retlw 'S'
retlw 't'
retlw 'a'
retlw 't'
retlw 'e'
retlw ','
retlw 0x20
retlw 'M'
retlw 'a'
retlw 'n'
retlw 'k'
retlw 'a'
retlw 't'
retlw 'o'
retlw 0
end
Thanks for your advice.
Analogue.
E - RA1
RS - RA2
D4 - RB4
D5 - RB5
D6 - RB6
D7 - RB7
; Processor: 16F84A
; Description:
; WARNING:
; switches
; * _CP_OFF
; _PWRTE_OFF
; * _WDT_OFF
processor 16f84A
#define E_line 1 ;|
cblock 0x0c
strData
endc
J ; counter J
K ; counter K
endc
; program
goto main
org 0x08
main:
movwf PORTA
movwf PORTB
; itself
call delay_5
; first LCD line
call blank16
; in text buffer
call storeMSU
call line1
call display16
; second LCD line
; in text buffer
call storeUniv
call display16
; done!
loopHere:
goto loopHere ;done
initLCD:
; 4-bit interface
; cursor on
; no display shift
; FUNCTION SET |
; | | | 0 = 1/16 dc
; | 0 = 4 bits
; | 1 = 8 bits
movlw 0x28
call send8
; | 1 = on, 0 = off
; |____ COMMAND BIT
call send8
; set entry mode |
; | | 1 = shift
; | | 0 = no shift
; |___ COMMAND BIT
call send8
; | shifted left
; | shifted right
; |___ COMMAND BIT
call send8
; clear display |
; |___ COMMAND BIT
call send8
; Per documentation
return
; 42 microseconds
delay_125
repeat
; 5 milliseconds
delay_5
delay
goto delay
; pulse E line
pulseE
nop
bcf PORTA,E_line
return
; (for debugging)
long_delay
movwf J ; J = w
goto kloop
goto jloop
return
display16
; Set up for data
movwf count3
getchar
; register
return
nextchar:
goto getchar
; send 2 nibbles in
; 4-bit mode
; ON ENTRY:
send8:
call merge4
movwf PORTB
call delay_125
return
; merge bits
; Logic:
; value = vvvv 0000
; vvvv bbbb
; ON ENTRY:
; ON EXIT:
merge4:
return
; blank buffer
; pic_ad
blank16
movwf count1
storeit
goto incfsr ; no
return ; yes
incfsr
goto storeit
; to LCD line 1
; ON ENTRY:
line1:
return
; to LCD line 2
; ON ENTRY:
line2:
call send8
return
storeMSU:
; ON ENTRY:
; in PIC RAM
; ON EXIT:
; w still = 0
get_msg_char:
andlw 0x0ff
endstr1:
return
msg1:
retlw 'M'
retlw 'i'
retlw 'n'
retlw 'n'
retlw 'e'
retlw 's'
retlw 'o'
retlw 't'
retlw 'a'
retlw 0
storeUniv:
; w still = 0
get_msg_char2:
andlw 0x0ff
endstr2:
return
msg2:
retlw 'S'
retlw 't'
retlw 'a'
retlw 't'
retlw 'e'
retlw ','
retlw 0x20
retlw 'M'
retlw 'a'
retlw 'n'
retlw 'k'
retlw 'a'
retlw 't'
retlw 'o'
retlw 0
end
Analogue.
