16F84A + stepper motor voltage regulator
supateach
Can someone one out there take a look at this PCB layout. I have redrawn all my PIC board layouts this year to include a voltage regulator so as to run 9& 12v motors from the same supply as the PIC. I have connected up a 12v stepper to a 28 pin board as on the layout and after blowing a couple of pics checked the voltage going to the pic and as soon as motor starts to run the voltage jumps from 5 to 12 blowing the pic, how can this be? The supply to the pic is after the regulator, how can the 12v for the stepper be getting to the PIC. Any advice gratefully received
Tony
You've got pin 10 of the driver chip connected incorrectly - it should go to the 12V supply at the top of the stepper motor. Connecting it to the 5 volt line means that the diodes in the chip feed the 12 volts from the motor to the 5 volt supply rail.
Nasty little mistake :cry:
