16F877A help
TKS
HI,
i have yet recieved my programmer (picall and made it ready to program the 18F series....)
i also have soldered a test board whit a led and a power mosfet and a switch...
now i want to start programming but my question was do i need to use a crystal??? for this chip..??? i thought it had one build in side if this is true which setting do i need to set..??/
TKS
PDF files
i also already downloaded ofcourse the pdf sheets but i have realy no idea where to start searching for this settings / options..??
TKS
by the datasheet you do need a crystal or a RC osc. since there is no mention of any internal osc.
Yes, you need a crystal, and two small capacitors (or use a ceramic resonator, with the capacitors built in). You can use a simple RC (resistor capacitor) external oscillator, but it's not very accurate - best to use a crystal.
ok here we goo.>!!
well i brought a 20Mhz crystal 6euro's..!!
and 2 very small capacitors (33pF???)
wired it up and then i saw that i was in plan suplying the VDD to pin 10 instead of pin 11 :cry: :oops: :shock:
soow now i have to wait to repait my sucker..!! jeejje :lol: :D :)
Nigel wich programmer do you use..??? i use the pic all it's a must if you want a scalable programmer i can easy add devices...to the programmer
it cost something but atleast it gives you something
TKS
Re: ok here we goo.>!!
I use the P16PRO40 with my own software, WinPicProg.
Mine doesn't cost anything :lol:
Re: PIC 18 series
TKS said:
ok but can you also program the pic18FXXX???
No, I've never had any interest in them, WinPicProg basically supports the chips I use - after all, it was written for my own use :lol:
IC-Prog is pretty good, and is free as well - I don't know if it supports the 18 series chips or not - I've never had occasion to look.
What I would like to do is buy a PicStart +, but I can't justify the money :( ( I have around 200 16C57XT's that I can't use ).
Re: Programming 16Cxxxx
TKS said:
that one is standard for my programmer..:D
Right, you have the picall programmer (not just the software), I've considered ordering one as well - just for the 16C57 - but I don't know what I'd use them for :lol:
