Speakerguy
Active Member
Hey,
I'm designing a PIC16LF876A board and want to use ICSP this time. The PIC is powered by a 3.7V lithium polymer battery which is connector to Vdd and then to MCLR through a 10k resistor.
I have a melabs U2 programmer. The ICSP pins I have are VPP, VDD, Data, Clock, and GND. VPP comes from the programmer and connects directly to the MCLR pin (I believe it drives a high voltage on this pin to erase the flash?). Anyway, I am desiring to know if ICSP works on an LF type PIC when it is powered by a 3.7V source or if this is entirely dependent on my programmer (I might just have to go read the melabs documentation if it is). I just wondered if anyone knew off the top of their heads if this sounded right or feasible. Thanks!
