16P20F [solved/workaround]
Grossel
Hi.
I'm looking for a datasheet for a dual diode / half rectifier in a TO220 package named labeled "16P20F". It's pretty much it's maximum ratings I'm trying to get.
It have being located in a AT power supply (spechial non-brand model that takes 110V DC input) built in the early 2000's.
I kind of find a datasheet at alldatasheet.com, but all characters in that pdf file is (i guess) are some asian vasriants and on screen they all appears as standing rectanges (not readable at all).
I also find other links on the web when searching, but all sites just get back to that same corrupted(*) pdf file.
* no offence if it turns out to be an asian language being used in that file, but on my screen the file appears broken.
I got this from alldatasheet.com for a C16P20FR, if that's the one you have, and it shows Chinese and English:
That is the one I found.
For me, it looks like this:
So, i'm not able to read the file so it make sense.
I am using Chrome, if that makes any difference?
How about now?
Ah, thanks.
I use Linux Lite and it's pre installed PDF viewer, Evince.
Then I tried to open the PDFs directly in Chromium, and I got similar result.
Temporarly workaround : in local folder, I just renamed the file, adding "(chrome only)" so I remember that it works in Chrome/Chromium next time I need to have a look into it.
Also tried to print from chromium (to PDF file) in hope that the end result file would be readable in pdf viewer, but no - still the same visible result.
Thought about doing the same as Inquisitive and posting screenshots from my machine, but hesitated as I was concerned about uploading unnecessary files to the server, when some kinda browser fix on the user-end would likely be the solution.
