justDIY
Active Member
I'm having a heck of a time getting the PLL to engage on my 18F2620.
Config fuses:
FOSC3:FOSC0 set to 1000 (int rc, io on ra7:6)
Registers:
PLLEN (OSCTUNE:6) = 1
IRCF2:IRCF0 (OSCCON6:4) = 111
according to the datasheet, that is all I need to set. yet when I flash the chip, the program runs very slowly, in fact, it runs at 1/4 speed, which means the chip is still running at 8mhz, even though I have all my timing routines calculated for 8*4 = 32
i'm using Proton PDS (proton basic)
any suggestions?
Config fuses:
Registers:
any suggestions?
2.6.4 PLL IN INTOSC MODES
The 4x frequency multiplier can be used with the internal oscillator block to produce faster device clock speeds than are normally possible with an internal oscillator. When enabled, the PLL produces a clock speed of up to 32 MHz.
Unlike HSPLL mode, the PLL is controlled through software. The control bit, PLLEN (OSCTUNE<6>), is used to enable or disable its operation.
The PLL is available when the device is configured to use the internal oscillator block as its primary clock source (FOSC3:FOSC0 = 1001 or 1000). Additionally, the PLL will only function when the selected output frequency is either 4 MHz or 8 MHz (OSCCON<6:4> = 111 or 110). If both of these conditions are not met, the PLL is disabled.
The PLLEN control bit is only functional in those internal oscillator modes where the PLL is available. In all other modes, it is forced to ‘0’ and is effectively unavailable.
