futz
Active Member
I wrote some 12F683 code to read an incoming servo pulse-train. Worked pretty well, but I have a small problem with it that I can't seem to find without a debugger. So I ported to 18F1320 (Junebug) and now I have a different problem that I can't find the solution to. It's probably something stupid I'm doing. ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The ISR captures the rising edge of each pulse just fine, but doesn't ever catch the falling edge. Here's the setup and ISR code:
Any ideas? I can post the whole thing if necessary.
EDIT: Oh ya, this might be pertinent - the incoming pulse-train is from a 3.3V ARM7. The 12F683 had no problem capturing it, so I doubt that that's the problem, especially since it captures the rising edges perfectly.
EDIT2: Just noticed that porta.RB3 is never going low. That's why it isn't capturing falling edges. Hmm... Wonder if I inadvertantly turned on weak-pullups? Checking now...
EDIT3: Nope, that wasn't it. Added a pulldown resistor just in case, but it didn't help.
ccp1con = 0b00000101; //capture rising edge
t1con = 0b00010001; //Timer1 enable, pre=2
t3con.T3CCP1 = 0; //Timer1 is clock source for CCP
rcon.IPEN = 0; //disable priority interrupts
pie1.CCP1IE = 1; //enable ccp1 interrupt
intcon.PEIE = 1; //enable peripheral interrupts
intcon.GIE = 1; //enable global interrupts
void interrupt(void)
if(porta.RB3){ //rising edge detected
start = ccpr1l; //store start value
start |= ccpr1h << 8;
ccp1con = 0b00000100; //set to capture falling edge
else{ //falling edge detected
end = ccpr1l; //store end value
end |= ccpr1h << 8;
ccp1con = 0b00000101; //set to capture rising edge
flag = 1;
if(end < start)
pwin = (0xffff - start) + end;
else
pwin = end - start;
pir1.CCP1IF = 0; //clear interrupt flag
