hello,
i'm using 18f452 for my project in which i'm checking a input pin(start command) if it is low then using timer3 i'm taking output for each 10milisecond and it will be continue unless and untill another input pin(stop command) goes low which i'm checking in isr routine its working properly but if i give start command and after some time without giving stop cammand if i pull RESET pin(MCLR pin no. 1 for 18f452) low then also the output comes why this is happening so.pls help me.
