18F4620 SPI SCK not working Oshonsoft.
camerart
Since changing to 18F4620 from 18LF4520, I haven't been able to get the SPI working.
The SPI SCK PIN doesn't appear to be switching as it should.
Here is a Logic analysis of the SPI PINS:
I've tried a PORT ON/OFF program, but the SCK PIN only switches between 0-0.5V
Camerart.
I read that the SPI SCK cant run too fast. I'm not sure if this is true, but I set the Program to
INT OSC 8MHz
osccon = %01110010
SSPCON1 = %0010000
and got this:
C.
INT OSC 8MHz
osccon = %01110010
SSPCON1 = %0010000
and got this:
C.
Oshonsoft uses software SPI.
No use for SSPCON1 = ...
It might interfere with software SPI?
I've now got the SPI SCK working.
(I've also got a program like a bag on knitting, so I won't post it:)
Thanks.
C.
I spoke too soon, regarding getting the SPI SCK working, as it was working up to a certain point.
After much analysing, it turns out to be the second PIC on the same PCB, sending a tick, which stopped the SCL. I've turned off the second PIC for now, then I'll investigate later.
Thanks, C.
