2-4 line dual demux with high output
richacm
Is there an equivalent of the 74LS139 which provides high outputs when selected instead of low outputs?
Thanks,
Craig
Did not Kchriste answer this for you in one of your other threads?
The 74HC238 will give you active high outputs. The 74HC138 will give active low outputs. The HCF4028 is also a good choice. Have fun.
Cool, thanks again!
This is exactly what I'm looking for...I knew there had to be one out there somewhere. I just wanted my outputs to be consistent with the rest of my pins being 5V for on and 0V for off. Otherwise it would start to get messy.
Craig
